Can Asus Tinker Board run LINUXCNC
6 years 11 months ago #149777 by andypugh
PCW wrote: Are you sure the driver is a hal component? That seems a bit odd
All the drivers are HAL components. i am a bit surprised that it compiled cleanly with halcompile, as typically it is hard to get the includes right, but it did, so looks like OK to me.
6 years 11 months ago - 6 years 11 months ago #149778 by PCW
I guess I just meant that that using halcompile outside of the norrnal LinuxCNC source tree for hm2 drivers seem odd
Last edit: 6 years 11 months ago by PCW.
6 years 11 months ago #149781 by andypugh
PCW wrote: I guess I just meant that that using halcompile outside of the norrnal LinuxCNC source tree for hm2 drivers seem odd
I agree, It might be worth trying an in-tree build, but it really did look to have gone smoothly, and it appeared to execute too.
6 years 11 months ago #149799 by terry1992
There are no hw_intf.conf in the boot folder of my tinker.
I think it might because of that the OS I use is armbian.
So I checked the hardware function again.
And just for refrence. The result of readhmid are as follows
atech@tinkerboard:~$ cd mesaflash atech@tinkerboard:~/mesaflash$ sudo ./mesaflash --device 7I90 --spi --addr /dev/spidev2.0 --readhmid [sudo] password for atech: unable to set bpw32, fallback to bpw8 Configuration Name: HOSTMOT2 General configuration information: BoardName : MESA7I90 FPGA Size: 9 KGates FPGA Pins: 144 Number of IO Ports: 3 Width of one I/O port: 24 Clock Low frequency: 100.0000 MHz Clock High frequency: 200.0000 MHz IDROM Type: 3 Instance Stride 0: 4 Instance Stride 1: 64 Register Stride 0: 256 Register Stride 1: 256 Modules in configuration: Module: WatchDog There are 1 of WatchDog in configuration Version: 0 Registers: 3 BaseAddress: 0C00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: IOPort There are 3 of IOPort in configuration Version: 0 Registers: 5 BaseAddress: 1000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: QCount There are 4 of QCount in configuration Version: 2 Registers: 5 BaseAddress: 3000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: PWM There are 4 of PWM in configuration Version: 0 Registers: 5 BaseAddress: 4100 ClockFrequency: 200.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: StepGen There are 8 of StepGen in configuration Version: 2 Registers: 10 BaseAddress: 2000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: LED There are 1 of LED in configuration Version: 0 Registers: 1 BaseAddress: 0200 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Configuration pin-out: IO Connections for P1 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 0 IOPort QCount 1 Quad-B (In) 3 1 IOPort QCount 1 Quad-A (In) 5 2 IOPort QCount 0 Quad-B (In) 7 3 IOPort QCount 0 Quad-A (In) 9 4 IOPort QCount 1 Quad-IDX (In) 11 5 IOPort QCount 0 Quad-IDX (In) 13 6 IOPort PWM 1 PWM (Out) 15 7 IOPort PWM 0 PWM (Out) 17 8 IOPort PWM 1 Dir (Out) 19 9 IOPort PWM 0 Dir (Out) 21 10 IOPort PWM 1 /Enable (Out) 23 11 IOPort PWM 0 /Enable (Out) 25 12 IOPort QCount 3 Quad-B (In) 27 13 IOPort QCount 3 Quad-A (In) 29 14 IOPort QCount 2 Quad-B (In) 31 15 IOPort QCount 2 Quad-A (In) 33 16 IOPort QCount 3 Quad-IDX (In) 35 17 IOPort QCount 2 Quad-IDX (In) 37 18 IOPort PWM 3 PWM (Out) 39 19 IOPort PWM 2 PWM (Out) 41 20 IOPort PWM 3 Dir (Out) 43 21 IOPort PWM 2 Dir (Out) 45 22 IOPort PWM 3 /Enable (Out) 47 23 IOPort PWM 2 /Enable (Out) IO Connections for P2 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 24 IOPort StepGen 0 Step/Table1 (Out) 3 25 IOPort StepGen 0 Dir/Table2 (Out) 5 26 IOPort StepGen 0 Table3 (Out) 7 27 IOPort StepGen 0 Table4 (Out) 9 28 IOPort StepGen 0 Table5 (Out) 11 29 IOPort StepGen 0 Table6 (Out) 13 30 IOPort StepGen 1 Step/Table1 (Out) 15 31 IOPort StepGen 1 Dir/Table2 (Out) 17 32 IOPort StepGen 1 Table3 (Out) 19 33 IOPort StepGen 1 Table4 (Out) 21 34 IOPort StepGen 1 Table5 (Out) 23 35 IOPort StepGen 1 Table6 (Out) 25 36 IOPort StepGen 2 Step/Table1 (Out) 27 37 IOPort StepGen 2 Dir/Table2 (Out) 29 38 IOPort StepGen 2 Table3 (Out) 31 39 IOPort StepGen 2 Table4 (Out) 33 40 IOPort StepGen 2 Table5 (Out) 35 41 IOPort StepGen 2 Table6 (Out) 37 42 IOPort StepGen 3 Step/Table1 (Out) 39 43 IOPort StepGen 3 Dir/Table2 (Out) 41 44 IOPort StepGen 3 Table3 (Out) 43 45 IOPort StepGen 3 Table4 (Out) 45 46 IOPort StepGen 3 Table5 (Out) 47 47 IOPort StepGen 3 Table6 (Out) IO Connections for P3 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 48 IOPort StepGen 4 Step/Table1 (Out) 3 49 IOPort StepGen 4 Dir/Table2 (Out) 5 50 IOPort StepGen 4 Table3 (Out) 7 51 IOPort StepGen 4 Table4 (Out) 9 52 IOPort StepGen 4 Table5 (Out) 11 53 IOPort StepGen 4 Table6 (Out) 13 54 IOPort StepGen 5 Step/Table1 (Out) 15 55 IOPort StepGen 5 Dir/Table2 (Out) 17 56 IOPort StepGen 5 Table3 (Out) 19 57 IOPort StepGen 5 Table4 (Out) 21 58 IOPort StepGen 5 Table5 (Out) 23 59 IOPort StepGen 5 Table6 (Out) 25 60 IOPort StepGen 6 Step/Table1 (Out) 27 61 IOPort StepGen 6 Dir/Table2 (Out) 29 62 IOPort StepGen 6 Table3 (Out) 31 63 IOPort StepGen 6 Table4 (Out) 33 64 IOPort StepGen 6 Table5 (Out) 35 65 IOPort StepGen 6 Table6 (Out) 37 66 IOPort StepGen 7 Step/Table1 (Out) 39 67 IOPort StepGen 7 Dir/Table2 (Out) 41 68 IOPort StepGen 7 Table3 (Out) 43 69 IOPort StepGen 7 Table4 (Out) 45 70 IOPort StepGen 7 Table5 (Out) 47 71 IOPort StepGen 7 Table6 (Out)
I also tried to do loadrt hm2_spi.
The result are as follows
atech@tinkerboard:~/linuxcnc-dev/src$ halrun halcmd: loadrt hostmot2 Waiting for component 'hostmot2' to become ready.....Waited 3 seconds for master. giving up. .Note: Using POSIX realtime hm2: loading Mesa HostMot2 driver version 0.15 halcmd: loadrt hm2_spi spidev_path="/dev/spidev2.0" probe 24000000 hm2_spi: rtapi_app_main: Permission denied (-13) <stdin>:2: waitpid failed /home/atech/linuxcnc-dev/bin/rtapi_app hm2_spi <stdin>:2: /home/atech/linuxcnc-dev/bin/rtapi_app exited without becoming ready <stdin>:2: insmod for hm2_spi failed, returned -1
6 years 11 months ago #149845 by andypugh
Are you sure that the board is in SPI2 and not SPI0?
Possibly SPI and SPIDEV are mutually exclusive?
6 years 11 months ago #149898 by terry1992
Yes, the 7i90hd card is connect to the spi2 pin of the tinker.( pin19=TX, pin21=RX, pin 23=CLK, pin24=csN0 )
However, I cannot tell if the hm2_tkboard use spi0 or spi2 from the source code.
I connect to spi2 because the author of the driver and the youtube video tell me it use spi2.
I also tried to do the spi communication when the spi2 is turned off and when spi2dev is turned off.(test1 & test2)
test1: spi2 : off spi2dev: on;
test2: spi2 : on spi2dev: off;
Both of the test shows cannot find device.
Time to create page: 0.283 seconds
