30 Nov 2023 00:10 - 30 Nov 2023 00:16 #286822 by rbobey1989
Replied by rbobey1989 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello everyone, I have continued investigating how to increase the counting speed for the qdc module, after looking at the firmware many times I have decided to look at the hardware of the board (the type of board does not matter EC500, EC300), multimeter in hand and measure continuity, after a few minutes I found that the +/-WHA and +/-WHB signals go directly to two optocouplers "B119V EL3H7" not to a differential driver as I had thought, along the way I also traced the other inputs that we could use with the qdc module and although I was already clear about these last inputs that they were connected to the "L247 M27" optocouplers, that said, I have not been able to find the data sheets for these optocouplers, although they are from other manufacturers (if anyone has information about these integrated ones, please report), I have the slight impression that these optocouplers will be a problem for reading the encoders although I must say that I have not tested the 24V inputs connected to the "L247 M27" optocouplers as I have to adjust the voltage levels.
A solution would be to unsolder these optocouplers, replace them with ones with faster times and try.
Please look at the previous post also where I documented the problem a little, regards.
Last edit: 30 Nov 2023 00:16 by rbobey1989.
30 Nov 2023 05:14 #286841 by cakeslob
yeah 0jw, looking at it now, in your hal change remora-eth to remora-eth-3.0 i think.
30 Nov 2023 06:33 #286846 by 0jw
Yes, I noticed that as well and noticed that for the remora-rt1052-basic/remora-ec500 it was just missing the remora-nv.so
Afterwards it worked for loading linuxcnc. So I'm trying to find the e-stop io to test further.
I also noticed a lot of spi functions in the remora-eth. Buy not really sure if that matters.
30 Nov 2023 16:48 - 30 Nov 2023 16:52 #286885 by 0jw
Unfortunately I'm still getting errors. When launching Linuxcnc I get "unexpected real time delay on task 0 with period 1000000"
When I try to click estop in Linuxcnc I can see the led next to the ethernet port flash. I found a asus d340mc-c desktop pc and tuned off aliasing and power save setting, then installed updates. From what info I could find this might have somthing to do with Intel ethernet. But I really have no idea.
Last edit: 30 Nov 2023 16:52 by 0jw.
30 Nov 2023 17:06 - 30 Nov 2023 18:13 #286888 by rbobey1989
hello everyone, I've been racking my brain to get a significant speed increase with a closed loop configuration, I've looked at the sample closed loop configuration from Scott's repository and I've noticed that the *.ini file has it configured a 100 scale encoder and I remembered that I had a 500ppr encoder, this already assuming the poor quality of the optocouplers (guys we have to deal with this, there is no other option...), well screwdriver in hand and I I got to work to change the disc marked 500ppr for the 1000ppr one to achieve a lower resolution and lower frequency in the encoder pulses, well pure mathematics I have achieved double the stable speed for closed circuit, I have no idea How much speed would be ideal for a milling machine, for example? but I have achieved about 2400mm/min for one axis, obviously if we continue lowering the resolution we could achieve greater speed, the project I would like to achieve would be to carry out a conversion of an HBM BF35 milling machine, I have no idea of the speed at which this machine could reach In order to find a relationship between speed and physical operation of the machine, if anyone has an idea about speeds for similar machines I am all ears, well guys, greetings
Last edit: 30 Nov 2023 18:13 by rbobey1989.
30 Nov 2023 17:07 #286889 by zmrdko
Whats your latency?
Try to run in terminal: latency-histogram —nobase —show
Let it run for a while
Also you can try to list exact hardware specs (incl ethernet adapter)
30 Nov 2023 18:37 #286895 by cakeslob
0jw post your hal/ini file
30 Nov 2023 21:47 #286909 by hanskuster
Replied by hanskuster on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I was able to confirm the direction output issues. My approach to getting the step and direction outputs into a "known" state during restarts was not consistent. So, with this bugfix I'm reading the actual output port DR register and then performing a direction change if needed. Happy testing and thanks again for the feedback. We'll get this stable.
I'll merge the bugfix branch once we have some feedback.
github.com/scottalford75/Remora-RT1052-c...t1052-3.1.1-beta.bin
Hi scotta,
I'm sorry for not seeing Your bugfix immediately! I was away for a short vacation.
I tried the version 3.1.1-beta. After every start the direction was always correct. I did about 15 starts.
The only problem I found instead is, I'm not able to upload a configuration. The remora stops its timers and that's it. The config upload repeats its requests, but doesn't get a response from the remora.
As a test I retried to upload the configuration again with version 3.1 and there it did work.
Regards, Hans
  • scotta
  • Platinum Member
  • Platinum Member
30 Nov 2023 23:17 #286915 by scotta
Hi scotta,
Regards, Hans
Thanks for testing! And discovering another problem. I'll check it out.
01 Dec 2023 03:21 #286924 by 0jw
the latency actually looks pretty bad on this desktop. I have youtube running in the background and some files open.
Time to create page: 0.348 seconds
