Remora - NVEM / EC300 / EC500
- zmrdko
- Thank you received: 49
12 Apr 2023 20:38 #268932
by zmrdko
Replied by zmrdko on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I have an ec500 with rt1052
- scotta
- Thank you received: 480
12 Apr 2023 22:31 #268941
by scotta
forum.linuxcnc.org/38-general-linuxcnc-q...rating-axis-movement
www.forum.linuxcnc.org/plasmac/45808-scale-axis#242146
Formula is: (distance commanded / distance moved) * old step scale = new step scale
Sounds like some calibration is needed to dial in the step scale.Thanks Scott. It was set to 0, but I changed it to 0.0001 and it seems to work fine now. I have now issue with motor accuracy. The scale is set to 160 and I have set jumpers on JMC ihsv57 motor to 800 steps per rotation so 5mm jog should be exactly one full circle. However its a little less than that. After few 5mm jogs its obvious. So do I have problem with step pulse lenghts?
The following user(s) said Thank You: zmrdko
- scotta
12 Apr 2023 22:33 #268942
by scotta
Yes, I saw that. But where is rxDataCopy being filled with the packet data?source/baseThread.c:
void makeSteps() { static int8_t i; static int32_t stepNow; if (rxDataFlag == 1) { rxDataFlag = 0; memcpy(rxDataCopy.rxBuffer, rxData.rxBuffer, BUFFER_SIZE); } .... but i think its better to move this part to the end of the makeSteps() function
- zmrdko
13 Apr 2023 00:38 - 13 Apr 2023 00:39 #268951
by zmrdko
Thanks Scott for patiently replying to all my queries.
i know this formula for correcting travel, but I was expecting the exact numbers to work. If the motor needs 800 pulses to make one turn, I would expect 160 scale times 5mm to work.
I have read that it might be caused by too short pulses. This is diagram I found in motor manual:
is there a way to set up these values?
Last edit: 13 Apr 2023 00:39 by zmrdko.
- scotta
13 Apr 2023 02:02 #268952
by scotta
Currently there is no step parameter settings configuration. Something in the pipeline though.
Your drive needs a 2.5 microsecond step pulse, the step pulse output form the Remora firmware is 25 microseconds in length. So should be ok. I'd do a step/mm calibration and run it though some test moves to check repeatability.
Nice motors BTW!
Nice motors BTW!
- meister
- Thank you received: 364
13 Apr 2023 05:56 - 13 Apr 2023 06:49 #268958
by meister
Following is the declaration for memcpy() function.void *memcpy(void *dest, const void * src, size_t n)
the memcpy command can be a bit confusing, because the first argument is the destination
Replied by meister on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Last edit: 13 Apr 2023 06:49 by meister.
- blazini36
- Thank you received: 166
15 Apr 2023 21:09 #269158
by blazini36
Replied by blazini36 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
What is the likelyhood of the 1052 firmware running on an imx rt1062? I've asked about Teensy 4.x firmware in the past which didn't get much traction but since there's ethernet firmware for a board running an rt1052, firmware for a Teensy 4.1 can't be too far off.
- frayja2002
- Thank you received: 12
16 Apr 2023 05:08 #269192
by frayja2002
Replied by frayja2002 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi Scott
Could I get you to check this
I am running an NVEM RT-1052, when I activate remora.output.00 OUT-2 comes on.
And vice versa. remora.output.01 turns OUT-1.
This seems to be backwards. Is this whats intended?
Alex
Alex
- scotta
16 Apr 2023 06:20 #269194
by scotta
No, nots what intended. I'll check it out but I'm thinking there may be a very subtle difference between the EC300 and NVEM. I developed on the EC300 as it has LEDs on the output. Everything else align numbering wise?
Hi Alex,Hi Scott
Alex
- frayja2002
16 Apr 2023 12:13 #269208
by frayja2002
I have now checked them.
All the other outputs seem to be in their natural order.
Alex.
Alex.
Time to create page: 0.298 seconds
