Keyboard re-mapping (key binding)
14 years 11 months ago #14705
by ioiotutu
Replied by ioiotutu on topic Re:Keyboard re-mapping (key binding)
It is clear.
I'll try.
Thanks.
I'll try.
Thanks.
14 years 11 months ago #14712
by ioiotutu
Thanks,
with this code in axisrc all work fine:
#swap bind key
# Bind ( and ) to jog axis 3 (0=X, 1=Y, 2=Z, 3=A, 4=B, ...)
root_window.bind("<Up>", lambda e: jog_on(0, -get_jog_speed(0)))
root_window.bind("<Down>", lambda e: jog_on(0, +get_jog_speed(0)))
root_window.bind("<KeyRelease-Up>", lambda e: jog_off(0))
root_window.bind("<KeyRelease-Down>", lambda e: jog_off(0))
root_window.bind("<Left>", lambda e: jog_on(1, -get_jog_speed(1)))
root_window.bind("<Right>", lambda e: jog_on(1, +get_jog_speed(1)))
root_window.bind("<KeyRelease-Left>", lambda e: jog_off(1))
root_window.bind("<KeyRelease-Right>", lambda e: jog_off(1))
#swap bind key
8 years 11 months ago #101360
by mrchar
Replied by mrchar on topic Re:Keyboard re-mapping (key binding)
Hello, how can I do this when I don't have .axisrc?
I have 2.7.11 linuxcnc
thank you
thank you
8 years 11 months ago #101383
Replied by andypugh on topic Re:Keyboard re-mapping (key binding)
You can just create the .axisrc file and it will be used.
Create it with the system text editor (probably Mousepad or Gedit) in your home folder.
8 years 11 months ago #101390
by mrchar
THANK YOU, it works!!!
8 years 9 months ago #105280
by Lazarov
Replied by Lazarov on topic Keyboard re-mapping (key binding)
Hello.
I trying to change the buttons on the keyboard but it does not work.
Left Arrow --> X-
Right Arrow --> X+
Up Arrow --> Y-
Down Arrow --> Y+
Where should I create the .axisrc file?
Here is my code in .axisrc file:
#swap bind key
root_window.bind("<Up>", lambda e: jog_on(1, -get_jog_speed(1)))
root_window.bind("<Down>", lambda e: jog_on(1, +get_jog_speed(1)))
root_window.bind("<KeyRelease-Up>", lambda e: jog_off(1))
root_window.bind("<KeyRelease-Down>", lambda e: jog_off(1))
root_window.bind("<Left>", lambda e: jog_on(0, +get_jog_speed(0)))
root_window.bind("<Right>", lambda e: jog_on(0, -get_jog_speed(0)))
root_window.bind("<KeyRelease-Left>", lambda e: jog_off(0))
root_window.bind("<KeyRelease-Right>", lambda e: jog_off(0))
Do you have any idea?
Š¢hank you in advance.
Left Arrow --> X-
Right Arrow --> X+
Up Arrow --> Y-
Down Arrow --> Y+
#swap bind key
Time to create page: 0.191 seconds
