Keyboard re-mapping (key binding)
14 years 11 months ago #14686 by ioiotutu
here is a scheme. image missing http://www.linuxcnc.org/media/kunena/attachments/legacy/images/scheme.jpg
14 years 11 months ago #14690 by BigJohnT
Ok, that makes sense the machine is correct but you don't stand in the conventional position. Have you give any thought to using a joy pad to jog with instead of lugging the keypad to the machine? Otherwise you would have to modify axis.py to change the key bindings. I scanned through the 3400 lines of code and nothing jumped out at me.
The following user(s) said Thank You: tcninja
14 years 11 months ago #14694 by andypugh
Is this thing on?
www.linuxcnc.org/component/option,com_ku.../lang,english/#14678
14 years 11 months ago #14701 by BigJohnT
Andy's suggestion to use .axisrc is better than my not so well thought out answer. If it exists, the contents of ~/.axisrc are executed as Python source code just before the AXIS gui is displayed. Putting your changes in .axisrc they won't get overwritten at the next upgrade...
14 years 11 months ago - 14 years 11 months ago #14702 by andypugh
Last edit: 14 years 11 months ago by andypugh.
14 years 11 months ago #14703 by BigJohnT
And Andy found this on the mailing list from one of the developers...
AXIS doesn't pay attention to jog keys with modifier keys pressed
because this had some bad interactions with using the numeric keypad as
digits in MDI mode.
You can put magic incantations in the file ~/.axisrc that customize the
jog keys and also get rid of this behavior of ignoring the key if a
modifier key is pressed.
Here is an example which changes the keys that jog the active axis, and
the keys that jog the A axis:
# -- cut here
# Bind ; and ' to jog active axis
root_window.bind("<semicolon>", commands.jog_minus)
root_window.bind("<apostrophe>", commands.jog_plus)
root_window.bind("<KeyRelease-semicolon>", commands.jog_stop)
root_window.bind("<KeyRelease-apostrophe>", commands.jog_stop)
# Bind ( and ) to jog axis 3 (0=X, 1=Y, 2=Z, 3=A, 4=B, ...)
root_window.bind("<parenleft>", lambda e: jog_on(3, -get_jog_speed(3)))
root_window.bind("<parenright>", lambda e: jog_on(3, get_jog_speed(3)))
root_window.bind("<KeyRelease-parenleft>", lambda e: jog_off(3))
root_window.bind("<KeyRelease-parenright>", lambda e: jog_off(3))
# -- cut here
To edit your ~/.axisrc file, open a terminal window (Applications > Accessories >
Terminal). Then type "gedit .axisrc". Paste the lines above into the file,
then click save, then close the application.
The next time you run emc, the settings in the .axisrc file will take effect.
To edit it again, just do the same thing: "gedit .axisrc" in the
terminal.
If you want to use different keys, here's how to figure out what to use instead
of "parenleft" and so on: In the terminal, type "xev". A new window
will pop up. Click on it, but keep an eye on the terminal window. When
you press a key, it will print several lines of information on the
terminal. The one that matters is this one:
state 0x0, keycode 34 (keysym 0x5b, bracketleft), same_screen YES,
that keysym string is the one to put in your .axisrc file.
Jeff
Time to create page: 0.235 seconds
