How does axisui work?
5 years 7 months ago #203521 by Aciera
Replied by Aciera on topic How does jogging work?
but linuxcnc error code 'halui.axis.x.plus' does not exist
Ah yes you are missing the entry 'HALUI = halui' in the [HAL]-section of your ini. So add it like this:
[HAL] # Add the halui user interface HALUI = halui # The run script first uses halcmd to execute any HALFILE # files, and then to execute any individual HALCMD commands. # list of hal config files to run through halcmd # files are executed in the order in which they appear HALFILE = MonoPump.hal # list of halcmd commands to execute # commands are executed in the order in which they appear #HALCMD = save neta
After that the halui pins should be available.
The following user(s) said Thank You: Jialan
5 years 7 months ago #203661 by Jialan
Replied by Jialan on topic How does axisui work?
By the way ,I use axisui.jog.increment net to halui.joint.0.increment
but linuxcnc is don't exist ,Why
5 years 7 months ago #203674 by Aciera
Replied by Aciera on topic How does axisui work?
The axisui. pins don't exist until after the axis-gui has been loaded so all your hal code that requires pins from GUIs, like axisui pins, need to be in a postgui.hal file.
1. Create a file in your 'config' folder. For example 'MonoPump_postgui.hal'
2. Copy your line inside 'MonoPump_postgui.hal' :
net yoursignalnamehere axisui.jog.increment halui.joint.0.increment
3. Save 'MonoPump_postgui.hal'
4. Add this line to the [HAL] section in your INI-file:
POSTGUI_HALFILE = MonoPump_postgui.hal
This line makes sure that MonoPump_postgui.hal is executed after the GUI (ie AXIS in your case) has been loaded.
5 years 7 months ago #203678 by Jialan
I will try it ,thank Aciera
5 years 6 months ago - 5 years 6 months ago #205055 by Jialan
my jog is working,but how does my jog is end
Last edit: 5 years 6 months ago by Jialan.
5 years 6 months ago #205070 by Aciera
Not sure what you mean there. Does the jog movement not end when you release the button?
Time to create page: 0.269 seconds
