XHC-HB04 wireless MPG pendant HAL module
11 years 9 months ago #55523 by andypugh
It finds the XHB
xhc-hb04: waiting for XHC-HB04 device xhc-hb04: found XHC-HB04 device xhc-hb04: connection lost, cleaning up
It looks like perhaps the USB port or the device might be faulty. (but that is a total guess)
I am a bit worried by this too:
[ 4367.563239] spurious APIC interrupt on CPU#1, should never happen.
Which might or might not be related.
Do you have any other USB ports you can try?
11 years 9 months ago #55525 by andypugh
ArcEye wrote: One of the errors is regards a pin on axis 3 ie. A axis
I missed that. Ignore my comments about USB for a while, that error might be the disconnect.
/usr/local/bin/xhc-hb04.hal:23: Pin 'axis.3.jog-enable' does not exist
Does that pin exist at any point?
11 years 9 months ago - 11 years 9 months ago #55531 by garulus
Thanks for replays. I just made fresh install of linuxcnc 2.6.5 and my pendant is plugged in. After command lsusb is shoving nicely as 10ce:eb70 Silicon Labs, so what next?
Last edit: 11 years 9 months ago by garulus.
11 years 9 months ago #55533 by dgarrett
Since you have now told us you have a 2.6 version,
you can try a sim config:
1) Plug in the pendant USB adapter 2) Start linuxcnc 3) In the Configuration Selector, select the xhc-hb04 directory: Sample Configurations sim axis xhc-hb04 Note: click on the + (plus sign) box to open each directory, click on the directory name to see its README, click on the configuration name to select it and see any configuration-specific information. 4) Select one of the sim configurations: xhc-hb04-layout1 xhc-hb04-layout2 xhc-hb04-layout2_mm And click OK to start the sim config
These sim configs will be copied to ~/linuxcnc/configs/
and there are instructions in the README for
modifying another configuration.
11 years 9 months ago #55534 by garulus
Great! It works! Previously I tried Sample Configurations/apps/xhc-....tomorrow will continue... :cheer:
11 years 9 months ago #55536 by dgarrett
The Sample Configurations/apps/ directory provides sample applications for demonstration and test but they are not complete linuxcnc configurations.
Sample Configurations/apps/xhc-hb04/README:
xhc-hbo4 standalone tests Use to test button layouts for a USB wireless xhc-hb04 pendant. xhc-hb04-layout1.demo -- test with layout1 (16 buttons) xhc-hb04-layout2.demo -- test with layout2 (18 buttons) xhc-hb04.demo -test with no predefined button layout (Connect a xhc-hb04 pendant and turn it on to use these programs)
The standalone app allows one to test that the buttons and jogwheel are working and you can verify the button names for the different pendant button layouts.
The following user(s) said Thank You: emcocnc
Time to create page: 0.373 seconds
