open loop servo tuning.
7 years 5 months ago #133051 by PCW
Replied by PCW on topic open loop servo tuning.
At least the example univstep.ini has these:
FERROR = 0.0100
MIN_FERROR = 0.001
( these settings would be way too small for a metric machine however )
The following user(s) said Thank You: skvallab
7 years 5 months ago #133117 by skvallab
Replied by skvallab on topic open loop servo tuning.
I'm sorry, i checked they had
FERROR & MIN_FERROR values,
FERROR = 0.010
MIN_FERROR = 0.001
i use my system in mm config.
and open loop, i just want the linux cnc to give pulse and direction to my servo drive.
i tried changing the value
Ferror = 0.1
Min_Ferror = 0.4
rate of error has reduced, but still couldnt get my velocity high.
7 years 5 months ago #133118 by skvallab
thanks , i increased the values
but still couldnt get my machine velocity to get high.
is there a way to disable linuxcnc 's PID generator., i just need it to give pulses, my servo drive can handle the PID.
7 years 5 months ago #133119 by andypugh
Replied by andypugh on topic open loop servo tuning.
Do you have 25% more STEPGEN_* (velocity and acceleration) than the Axis is configured for?
Stepgen following errors simply mean that not enough steps have been sent to achive the target position (ie, the following errors you are seeing are _real_ and need to be configured away rather than ignored.
7 years 5 months ago #133120 by skvallab
Have increased the max_velocity of axis 1 = 505
pid-max-vel = 506
still not able to achieve my reqd. velocity.
my motor rated rpm is 1500, it looks like it is just running at 150 to 300 max.
7 years 5 months ago #133121 by skvallab
Now i'm not getting errors. just velocity is low., PID max vel and max velocity has been increased and still i dont see difference in my servo's speed. it still stands the same
Time to create page: 0.058 seconds
