- Thank you received: 267
Gildemeister NEF 480 Retrofit
5 years 6 months ago #205085
by anfänger
Replied by anfänger on topic Gildemeister NEF 480 Retrofit
L2 ( my 2nd Phase on the first phase are already the Computer and 5 and 24V power supply the second drive is on L3 ) to L1
L2 empty
N to L3
L2 to L2C (I use two breakers one for the control loop and one for the main loop)
N to L1C
B2 and B3 are Bridged.
Motor is not connected.
DI0 (Servo enable) is low
DI1(Alarm release) is low
And within 30 sec its getting hot.
With all the VFD‘s I used fo far they never went warm so quick and never without motor load.
L2 empty
N to L3
N to L1C
5 years 6 months ago #205088
by RotarySMP
Replied by RotarySMP on topic Gildemeister NEF 480 Retrofit
You are in Europe and have 380V or 400V 3 phase aren't you? 220V three phase is a US thing.
I can't follow what you wrote. When you talk about connecting a single phase and it getting hot, are you connecting between phase and neutral (= 230V) or are you connecting between two phase wires (= 400V).
Mark
Mark
5 years 6 months ago #205092
by anfänger
I am connecting between a single phase an neutral (230V)
But since this is making troubles I was thinking about using a 3x400 V to 3x220V Transformer. And was wondering if one of my old ones might fit, but it turned out they don‘t.
But as it seems I am doing everything right I will give the 2nd drive a chance. Maybe there is simply something wrong with the first.
Many thanks fo all the support here!
5 years 6 months ago #205093
by RotarySMP
Did you determine L and N based on color? Have you measured the voltage? Some electricians are either color blind, or consider color coding as more of an optional recommendation than a standard.
5 years 6 months ago #205098
by anfänger
Since I did all the wiring the colors / Numbers should be correct.
But I will rewire to make before starting the 2n one
5 years 6 months ago #205113
by db1981
Replied by db1981 on topic Gildemeister NEF 480 Retrofit
Wiring is correct, that should not get hot.
Are you shure you have an proper "N".?
Wenn der N in der Verteilung fehlt, oder die Maschine an ner alten 4 adrigen "Bauerndrehstrom"Dose ohne N hängt. Kann es passieren das du im Schaltschrank 400V zwischen N und Phase hast, da der Sternpunkt fehlt. Mess mal ob der N am Servoregler Verbindung zum N von ner normalen Schuko Dose im Raum hat...
Time to create page: 0.076 seconds
