- Thank you received: 267
Gildemeister NEF 480 Retrofit
5 years 9 months ago #195972
by anfänger
Replied by anfänger on topic Gildemeister NEF 480 Retrofit
So did the first board test yesterday:
[/url]
Ok the first after playing pin pong. Let’s call it first contact from LinuxCNC to the mesa card.
And tested my hand wheels. And it works... Next step is to see if I get the spindle encoder running but I have no Pinout is there a kind of standard with color coding in the cable or the plugs? Otherwise I screwed and need to find a new encoder that fits.
[/url]
5 years 9 months ago #195991
Do you have any information about the encoder at all?
Replied by Aciera on topic Gildemeister NEF 480 Retrofit
5 years 9 months ago #196003
Replied by PCW on topic Gildemeister NEF 480 Retrofit
Even with no information on an encoder, you can possibly
determine the power supply connections by continuity
testing from known IC ground and power pins to cable
connections. Once you have figured out the power
connections, you can power the encoder and then
determine the other signals with a voltmeter
5 years 9 months ago #196012
by anfänger
this is more ore less the way I want to try it
Type TSI508 then its not readable.
Power supply 5v cd number of increments is all not readable, but easy for figure out
A86L-0024-0001
There is also an engraving C4063 but I think this is for the interface
maybe the color code for my Siemens encoders will work.. otherwise it a session with the multimeter.
A86L-0024-0001
5 years 9 months ago #196018
by anfänger
I figured out the outputs. But it looks like it has some problem.
I opend it and found some of the degreaser in it not much but maybe it did some harm. I wonder if I can do something.
It could be also have issues before. I don’t know
- Thank you received: 1480
5 years 9 months ago #196023
Replied by Todd Zuercher on topic Gildemeister NEF 480 Retrofit
Why do you think it has issues? The watch screen in Halshow is not a reliable way to watch for quadrature error. The update frequency is much much too slow and in user-space. Infact watching the A and B signal pins in Halscope probably isn't even good enough since that is only sampled in the servo thread. I'd say as long as the count seems reasonable and it isn't setting quadrature error alarms, it's probably ok.
Time to create page: 0.562 seconds
