Gildemeister NEF 480 Retrofit
5 years 9 months ago #196607 by anfänger
Yesterday evening I failed to make real progress. Took me half evening to get my M-Codes executed, just to realise I am not able to map bash scripts to M codes < 100.
So trying again this evening with python. And then hopefully getting the q&d solution for the gearbox running.
Did I mention that I need more leisure time to get my hobby projects done...
5 years 9 months ago #196714 by anfänger
With a lot of help of this forum and a midnight session yesterday, I got the first test of my two stage gearbox solution running
The gear selection is blocked while the spindle is running.
When the first gear set is changed the parameters of the second stage will be adjusted.
Now seeing what I have done with a night of sleep in between I might redo it...
It calculate the whole scale for both stages and insert it, so I only use the first stage for storing parameters.
So I can skip the first stage in hal and move that to my script. And the make ist neat maybe move it to python, make a nice dialog, find a way to get it in my post processor.... I see a lot of sleepless nights coming
But now it’s in an stage where I can start testing it with hardware... At least I thin so, till I fry something.
5 years 9 months ago #197221 by anfänger
Did not do much on the lathe project this weekend, just finished some drawings:
[img
this will become the new lid for the console. Left are the holes for E-stop and the mpgs right the holes fo the touch screen.
[img
and the interface to fit the new encoder to the spindle.
maybe I'll fiddle around with the vcp later
5 years 9 months ago #197224 by RotarySMP
You are making great progress. Nice lathe.
Mark
5 years 8 months ago - 5 years 8 months ago #197592 by anfänger
thanks, you are probably right it‘s just I wish I found more will to go to the shop after work.
[img
Estop and the optional Modbus interface for the VFD arrived.
Also I spend the evening laying out the cabinet.
Now only the spindle encoder is missing for the electrical part.
What I am not sure about is how and where to put it relative to my mill and the lathe it self...
Last edit: 5 years 8 months ago by anfänger.
5 years 8 months ago #197690 by anfänger
Started assembling the cabinet. The Mesa card is still not in there, but the rest. Next step is to wire this all up.
[img
Time to create page: 0.637 seconds
