Gildemeister NEF 480 Retrofit
5 years 10 months ago #193407 by anfänger
The first order for the retrofit arrived
[img
Not really enough to really start but I haven't finished cleaning but made some progress a complete bucket of grime and chips is already full
[img
[img
[img
The rear cable canal still needs to be cleaned from the grime and I avoided the coolant tank.
[img
[img
it looks quite messy ​and will be something I will happily postpone once more. But enough for now the next delivery guy is ringing...
5 years 10 months ago #193420 by anfänger
and he brought some CEE cables and connectors
[img
Ohne Titel
and the Mesa card arrived.
[img
Ohne Titel
still not enough to start but let's see what tomorrow delivery will bring.
5 years 10 months ago #193503 by anfänger
today some more stuff arrived
[img
Ohne Titel
now I can start thinking about taking care of the wiring
5 years 10 months ago - 5 years 10 months ago #193673 by anfänger
Today the computer arrived:
I also started to remove the old control:
and the first of the old servos left the machine:
I also removes the housing to get better access to the machine for future rewiring:
I also started to pull and lay out the old cables:
Still in the cleaning and preparing phase of this project I am really looking forward the I can assemble again
at the moment the table with the removed parts is starting to be filled:
more next year
Last edit: 5 years 10 months ago by anfänger.
5 years 10 months ago #193747 by anfänger
So installed linuxcnc today. It's not the final monitor but I wanted to start
latencies look okish without W-Lan and disabled audio
also flipped the cabinet around, now it's right siede up.
[img
After taking a look at the back:
[img
I decided ti scrap everything but the hart plugs even the main switch will go. So its waiting again and cleaning a lot of cleaning
The following user(s) said Thank You: chimeno, tommylight, Aciera
5 years 9 months ago #193847 by anfänger
emptied the cabinet today
work in progress:
and in the end:
and here is all the stuff I removed:
nest is cleaning and then building it up again.
Time to create page: 3.894 seconds
