Mesa 5i24 mesaflash : No 5I24 board found
10 years 2 months ago - 10 years 2 months ago #78742
by erasmo
Replied by erasmo on topic Mesa 5i24 mesaflash : No 5I24 board found
P2 7i65
P4 7i44
sudo ./mesaflash --device 5i24 --readhmid
[sudo] password for robert:
Configuration Name: HOSTMOT2
BoardName : MESA5I24
FPGA Size: 16 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 24
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxQCnt
There are 16 of MuxQCnt in configuration
Version: 3
Registers: 5
BaseAddress: 3600
Module: MuxQSel
There are 1 of MuxQSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: BufSPI
There are 2 of BufSPI in configuration
Version: 0
Registers: 3
BaseAddress: 5500
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort MuxQCnt 0 MuxQ-IDX (In)
3 1 IOPort MuxQCnt 0 MuxQ-IDX (In)
5 2 IOPort MuxQCnt 0 MuxQ-IDX (In)
7 3 IOPort MuxQCnt 1 MuxQ-IDX (In)
9 4 IOPort MuxQCnt 1 MuxQ-IDX (In)
11 5 IOPort MuxQCnt 1 MuxQ-IDX (In)
13 6 IOPort MuxQCnt 2 MuxQ-IDX (In)
15 7 IOPort MuxQCnt 2 MuxQ-IDX (In)
17 8 IOPort MuxQCnt 2 MuxQ-IDX (In)
19 9 IOPort MuxQCnt 3 MuxQ-IDX (In)
21 10 IOPort MuxQCnt 3 MuxQ-IDX (In)
23 11 IOPort MuxQCnt 3 MuxQ-IDX (In)
25 12 IOPort Null 0 Null3 (null) (In)
27 13 IOPort MuxQSel 0 Null3 (Out)
29 14 IOPort BufSPI 0 SClk (Out)
31 15 IOPort BufSPI 0 SClk (Out)
33 16 IOPort BufSPI 0 SClk (Out)
35 17 IOPort BufSPI 0 SClk (In)
37 18 IOPort BufSPI 0 SClk (Out)
39 19 IOPort BufSPI 0 SClk (Out)
41 20 IOPort BufSPI 0 SClk (Out)
43 21 IOPort Null 0 Null3 (null) (In)
45 22 IOPort Null 0 Null3 (null) (In)
47 23 IOPort Null 0 Null3 (null) (In)
IO Connections for P3
1 24 IOPort MuxQCnt 4 MuxQ-IDX (In)
3 25 IOPort MuxQCnt 4 MuxQ-IDX (In)
5 26 IOPort MuxQCnt 4 MuxQ-IDX (In)
7 27 IOPort MuxQCnt 5 MuxQ-IDX (In)
9 28 IOPort MuxQCnt 5 MuxQ-IDX (In)
11 29 IOPort MuxQCnt 5 MuxQ-IDX (In)
13 30 IOPort MuxQCnt 6 MuxQ-IDX (In)
15 31 IOPort MuxQCnt 6 MuxQ-IDX (In)
17 32 IOPort MuxQCnt 6 MuxQ-IDX (In)
19 33 IOPort MuxQCnt 7 MuxQ-IDX (In)
21 34 IOPort MuxQCnt 7 MuxQ-IDX (In)
23 35 IOPort MuxQCnt 7 MuxQ-IDX (In)
25 36 IOPort Null 0 Null3 (null) (In)
27 37 IOPort MuxQSel 8 Null3 (Out)
29 38 IOPort BufSPI 1 SClk (Out)
31 39 IOPort BufSPI 1 SClk (Out)
33 40 IOPort BufSPI 1 SClk (Out)
35 41 IOPort BufSPI 1 SClk (In)
37 42 IOPort BufSPI 1 SClk (Out)
39 43 IOPort BufSPI 1 SClk (Out)
41 44 IOPort BufSPI 1 SClk (Out)
43 45 IOPort Null 0 Null3 (null) (In)
45 46 IOPort Null 0 Null3 (null) (In)
47 47 IOPort Null 0 Null3 (null) (In)
IO Connections for P4
1 48 IOPort SSerial 0 RXData1 (In)
3 49 IOPort SSerial 0 RXData2 (In)
5 50 IOPort SSerial 0 RXData3 (In)
7 51 IOPort SSerial 0 RXData4 (In)
9 52 IOPort SSerial 0 TXData1 (Out)
11 53 IOPort SSerial 0 TXEn1 (Out)
13 54 IOPort SSerial 0 TXData2 (Out)
15 55 IOPort SSerial 0 TXEn2 (Out)
17 56 IOPort SSerial 0 TXData3 (Out)
19 57 IOPort SSerial 0 TXEn3 (Out)
21 58 IOPort SSerial 0 TXData4 (Out)
23 59 IOPort SSerial 0 TXEn4 (Out)
25 60 IOPort SSerial 0 RXData5 (In)
27 61 IOPort SSerial 0 RXData6 (In)
29 62 IOPort SSerial 0 RXData7 (In)
31 63 IOPort SSerial 0 RXData8 (In)
33 64 IOPort SSerial 0 TXData5 (Out)
35 65 IOPort SSerial 0 TXEn5 (Out)
37 66 IOPort SSerial 0 TXData6 (Out)
39 67 IOPort SSerial 0 TXEn6 (Out)
41 68 IOPort SSerial 0 TXData7 (Out)
43 69 IOPort SSerial 0 TXEn7 (Out)
45 70 IOPort SSerial 0 TXData8 (Out)
47 71 IOPort SSerial 0 TXEn8 (Out)
P4 7i44
FPGA Pins: 256
IDROM Type: 3
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxQCnt
Version: 3
Registers: 5
BaseAddress: 3600
Module: MuxQSel
Version: 0
Registers: 0
BaseAddress: 0000
Module: BufSPI
Version: 0
Registers: 3
BaseAddress: 5500
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
Last edit: 10 years 2 months ago by erasmo.
10 years 2 months ago #78744
Replied by PCW on topic Mesa 5i24 mesaflash : No 5I24 board found
It looks like Mesaflash or the manual is wrong about connector numbers
I would try swapping P2 and P4
10 years 2 months ago - 10 years 2 months ago #78752
by erasmo
Yes that was it, after swapping P2 & P4
7i44 - all works fine
7i65 - encoder works fine
After
loadrt mesa_7i65 bspi_chans=hm2_5i24.0.bspi.0
there is still no voltage on phisical pins after setting signal on mesa-7i65.0.analogue.1.out
After
10 years 2 months ago #78756
by erasmo
I can't get analog voltages working.
10 years 2 months ago #78762
Do you have the 7I65 component loaded?
10 years 2 months ago #78789
by erasmo
Yes I loaded component using
component loaded succesfully but that did not change anything
still no voltage on AOUT0, AOUT1... etc, pins
Time to create page: 0.056 seconds
