My 7i76e Connection Sheet
4 years 1 month ago #252918 by Karri
Replied by Karri on topic My 7i76e Connection Sheet
Hi
Could someone double check my schema to use 12V as logic power and 5V as field power
BR:Karri
4 years 4 weeks ago - 4 years 4 weeks ago #253438 by fons
Replied by fons on topic My 7i76e Connection Sheet
as fare as i see on my setup
just conect the power conector tb1
gnd at pin 8 (the side of the board) + 12v (+24v) at pin 2
it look like pin 1, 2, 3, 4 and 5 are the same and give power to tb6 and tb5
on tb6 are no gnd conections to make only one common gnd conected to pin 8 on tb4
pin 1 to 4 can be used as analog or digital input
pin 5 to 16 are digital input
pin 17 to 24 are digital output
Last edit: 4 years 4 weeks ago by fons.
4 years 4 weeks ago #253496 by rodw
Replied by rodw on topic My 7i76e Connection Sheet
Whats wrong with connecting to TB3? Its there for this purpose. I use it.
3 years 8 months ago #264840 by fons
a year ago  i work on a mile machine  and that time  it work it move  i work with mesa 7i76e.
i have 2 setups   a big one in the workshop (way to cold now) and a smale one (coosie warm) to experimenting  in house
it stay  there  unused   no time   and now i pick it  up again
the one in the workshop stil work
when i take the laptop  in house  i got  an error  when i take the laptop again to the workshop  with the same config work
what can be the reason
i got these error message  the last lines
hm2/hm2_7i76e.0: registered
hm2_eth: hostmot2 ethernet driver unloaded
hm2: unloading
removing hal_lib, rtapi, and real time os modules
removing nml shared memory segment
debug file information
note: using posix realtime
./sin20220818.hal: pin 'hm2_7i76e.0.7i76.0.0.output-00' does not exist 1552
stopping realtime threads
unloading hal components
someone had an idea  how i can solve thise problem  ?
3 years 8 months ago #264842 by PCW
Replied by PCW on topic My 7i76e Connection Sheet
Typically, that error means that the 7I76E does not have field power
The following user(s) said Thank You: fons
3 years 8 months ago #264843 by fons
for noise reason i didn't switch it  on and that was critical  thx  it work  now
Moderators: PCW, jmelson
Time to create page: 0.291 seconds
