My 7i76e Connection Sheet
2 years 9 months ago - 2 years 9 months ago #291424 by Amin Laakel Sofet
Hi, I'm having a similar error code when trying to run LinuxCNC
Note: Using POSIX realtime
".custom.hal:81: Pin 'hm2_7i76e.0.7i76.0.0.enc0.count' does not exist"
3999
(The 3999 number changes everytime we try to start up the program)
This only happens when we use a specific code in our custom.hal to control the axis' with a MPG controller.
We've already checked the field power TB1 (pin 5 +24V pin 8 GND) and when we measure P3 there is a 5V available.
The Custom.Hal we used is below.
loadrt mux4 count=1
loadrt mux8 count=1
loadrt select8 count=1
loadrt conv_float_s32 count=1
addf mux4.0 servo-thread
addf mux8.0 servo-thread
addf select8.0 servo-thread
addf conv-float-s32.0 servo-thread
# For velocity mode, set to 1
# In velocity mode the axis stops when the dial is stopped
# even if that means the commanded motion is not completed,
# For position mode (the default), set to 0
# In position mode the axis will move exactly jog-scale
# units for each count, regardless of how long that might take,
setp axis.x.jog-vel-mode 0
setp axis.y.jog-vel-mode 0
setp axis.z.jog-vel-mode 0
# This sets the scale that will be used based on the input to the mux4
setp mux4.0.in1 0.001
setp mux4.0.in2 0.01
setp mux4.0.in3 0.1
# This selects axis (off=0, x=1, y=2, ...)
setp mux8.0.in0 0
setp mux8.0.in1 1
setp mux8.0.in2 2
setp mux8.0.in3 3
setp mux8.0.in4 4
setp mux8.0.in5 5
setp mux8.0.in6 6
setp mux8.0.in7 7
# The inputs to the mux4 component
net scale1 mux4.0.sel0 <= hm2_7i76e.0.7i76.0.0.input-20
net scale2 mux4.0.sel1 <= hm2_7i76e.0.7i76.0.0.input-21
# The inputs to the mux8 component
net mux8-sel0 <= hm2_7i76e.0.7i76.0.0.input-22
net mux8-sel1 <= hm2_7i76e.0.7i76.0.0.input-23
net mux8-sel2 <= hm2_7i76e.0.7i76.0.0.input-24
net mux8-sel0 => mux8.0.sel0
net mux8-sel1 => mux8.0.sel1
net mux8-sel2 => mux8.0.sel2
net mux-float conv-float-s32.0.in <= mux8.0.out
net mux-s32 <= conv-float-s32.0.out
net mux-s32 => select8.0.sel
net axis-select-x <= select8.0.out1
net axis-select-y <= select8.0.out2
net axis-select-z <= select8.0.out3
net axis-select-4 <= select8.0.out4
net axis-select-5 <= select8.0.out5
net axis-select-6 <= select8.0.out6
net axis-select-x => axis.x.jog-enable
net axis-select-y => axis.y.jog-enable
net axis-select-z => axis.z.jog-enable
# The output from the mux4 is sent to each axis jog scale
net mpg-scale <= mux4.0.out
net mpg-scale => axis.x.jog-scale
net mpg-scale => axis.y.jog-scale
net mpg-scale => axis.z.jog-scale
# The encoder output counts to the axis. Only the selected axis will move.
net encoder-counts <= hm2_7i76e.0.7i76.0.0.enc0.count
net encoder-counts => axis.x.jog-counts
net encoder-counts => axis.y.jog-counts
net encoder-counts => axis.z.jog-counts
Last edit: 2 years 9 months ago by Amin Laakel Sofet.
2 years 9 months ago #291426 by tommylight
In the main hal file, the loadrt line, does it set the board to mode 1 or mode 2?
Same line, does it have number of encoders at anything but 0?
Normally encoder 0 would be the spindle encoder, are you using that for MPG?
2 years 9 months ago #291506 by Amin Laakel Sofet
These are the loadrt lines that show up in the main Hal file.
We haven't fully configured the spindle encoder yet, because we were trying to figure out how to move the axis' with the MPG, is it possible that the encoder needs to be fully functional before we can use the MPG for the axis'?
Thanks in advance
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
setp hm2_7i76e.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
2 years 9 months ago #291539 by PCW
Replied by PCW on topic My 7i76e Connection Sheet
You would need mode 2 on the 7I76Es I/O section to enable the MPGs:
sserial_port_0=20xxxx
The following user(s) said Thank You: Amin Laakel Sofet
2 years 9 months ago #291663 by Amin Laakel Sofet
Thanks for the help we got the MPG to fully work after changing the mode to 20 and reconnecting some loose wires.
Moderators: PCW, jmelson
Time to create page: 0.369 seconds
