i found some info
the spindeldrive
reliance electric compay cleveland ohio model 1gaq811/1 30hp date 12/14/79 untill now i don't find any info
ac in 480v 50/60 hz 3ph 69.4A
dc out 240v 108A
x and z axe
driver inland motor kollmorgen ireland dpar 3330-00 serial 695 untill now i don't find any info
motor continue 15v 20A 10 lb/ft peak 67v 90A 45 lb/ft
tured 2 times
aerotech inc model 6020hr 690-1037 rev "g" dash #2 10 amp cont online i found a user manual this drive had no secret anymore
shaft encoder all 5 are the same
heidenhain model 421m.0000,3600 s8 (it was wrong in me previous post ) i found the wire colors in orginal box in the lath machine
where can you buy a dc servo driver for experiment testsetup i don't find one even not on aliexpress for a low price
i take the encoder out of the machine and had a clear vieuw of the number and there was another rcd in frond
the whole number is rcd 421m.0000, 3600
i already found also th original box of the encoder with inside the color code of the wires
its a 5v ttl folloing the paper i found
for info of the drivers is a bigger isue
i can folow the color of the wires so i have anidea what is input signal +/- 10v there is also the drive enable and a 3th wire where i haven't any idea what it can do
maybe some of the people here use or had info about that driver ?
