Brother TC-225 Retrofit and Robot integration
5 years 6 months ago #204754 by andypugh
timfaber wrote: it seems to stop at
./basic7i97.hal:225: Unknown command '3600'
What does line 225 of basic7i97.hal say? (At a guess, there is a spurious linefeed)
The following user(s) said Thank You: timfaber
5 years 6 months ago #204761 by timfaber
Yes there was, I can run axis now. Its very slow.
Next step will be to let a led blink or something, also I made a quick video about my machine. If anyone is interested:
5 years 6 months ago #204777 by tommylight
timfaber wrote: That didn't work for me
timfaber@Brother:~$ sudo apt-get install /mesaflash_3.4.0~pre1-1_amd64.deb
Used this instead, dont know if it did the trick?
timfaber@Brother:~$ sudo dpkg -i ./mesaflash_3.4.0~pre1-1_amd64.deb
Missing . in front of the / in the apt-get line.
Use of dpkg is not advised as it does not check for dependencies in some cases.
5 years 6 months ago #204778 by timfaber
Been digging a bit more in the docs and my hal file, came up with some things still a bit unclear to me.
readhmi gave me the following:
timfaber@Brother:~$ mesaflash --device ethernet --addr 10.10.10.10 --readhmid Configuration Name: HOSTMOT2 General configuration information: BoardName : MESA7I97 FPGA Size: 9 KGates FPGA Pins: 144 Number of IO Ports: 3 Width of one I/O port: 17 Clock Low frequency: 100.0000 MHz Clock High frequency: 200.0000 MHz IDROM Type: 3 Instance Stride 0: 4 Instance Stride 1: 64 Register Stride 0: 256 Register Stride 1: 256 Modules in configuration: Module: DPLL There are 1 of DPLL in configuration Version: 0 Registers: 7 BaseAddress: 7000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: WatchDog There are 1 of WatchDog in configuration Version: 0 Registers: 3 BaseAddress: 0C00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: IOPort There are 3 of IOPort in configuration Version: 0 Registers: 5 BaseAddress: 1000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: MuxedQCount There are 6 of MuxedQCount in configuration Version: 3 Registers: 5 BaseAddress: 3600 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: MuxedQCountSel There are 1 of MuxedQCountSel in configuration Version: 0 Registers: 0 BaseAddress: 0000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: SSerial There are 1 of SSerial in configuration Version: 0 Registers: 6 BaseAddress: 5B00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 64 bytes Module: PWM There are 6 of PWM in configuration Version: 0 Registers: 5 BaseAddress: 4100 ClockFrequency: 200.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: SSR There are 1 of SSR in configuration Version: 0 Registers: 2 BaseAddress: 7D00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: InMux There are 1 of InMux in configuration Version: 0 Registers: 5 BaseAddress: 8000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: LED There are 1 of LED in configuration Version: 0 Registers: 1 BaseAddress: 0200 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Configuration pin-out: IO Connections for TB1/TB2/TB3 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir TB3-4 0 IOPort PWM 0 PWM (Out) TB3-8 1 IOPort PWM 1 PWM (Out) TB3-12 2 IOPort PWM 2 PWM (Out) TB3-16 3 IOPort PWM 3 PWM (Out) TB3-20 4 IOPort PWM 4 PWM (Out) TB3-20 5 IOPort PWM 4 /Enable (Out) TB3-24 6 IOPort PWM 5 PWM (Out) TB3-24 7 IOPort PWM 5 /Enable (Out) TB3-4,8,12,16 8 IOPort PWM 0 /Enable (Out) TB1-1,2,9,10 9 IOPort MuxedQCount 0 MuxQ-A (In) TB1-4,5,12,13 10 IOPort MuxedQCount 0 MuxQ-B (In) TB1-7,8,15,16 11 IOPort MuxedQCount 0 MuxQ-IDX (In) TB1-17,18,TB2 1,2 12 IOPort MuxedQCount 1 MuxQ-A (In) TB1-20,21,TB2-4,5 13 IOPort MuxedQCount 1 MuxQ-B (In) TB1-23,24,TB2-7,8 14 IOPort MuxedQCount 1 MuxQ-IDX (In) TB2-9,10,17,18 15 IOPort MuxedQCount 2 MuxQ-A (In) TB2-12,13,20,21 16 IOPort MuxedQCount 2 MuxQ-B (In) IO Connections for TB4/TB5 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir TB2-15,16,23,24 17 IOPort MuxedQCount 2 MuxQ-IDX (In) Internal 18 IOPort MuxedQCountSel 0 MuxSel0 (Out) TB5-13,14 19 IOPort SSR 0 Out-00 (Out) TB5-15,16 20 IOPort SSR 0 Out-01 (Out) TB5-17,18 21 IOPort SSR 0 Out-02 (Out) TB5-19,20 22 IOPort SSR 0 Out-03 (Out) TB5-21,22 23 IOPort SSR 0 Out-04 (Out) TB5-23,24 24 IOPort SSR 0 Out-05 (Out) Internal 25 IOPort SSR 0 AC Ref (Out) Internal 26 IOPort InMux 0 Addr0 (Out) Internal 27 IOPort InMux 0 Addr1 (Out) Internal 28 IOPort InMux 0 Addr2 (Out) Internal 29 IOPort InMux 0 Addr3 (Out) Internal 30 IOPort InMux 0 Data0 (In) TB4-15,16 31 IOPort SSerial 0 RXData0 (In) TB4-17,18 32 IOPort SSerial 0 TXData0 (Out) Internal 33 IOPort SSerial 0 TXEn0 (Out) IO Connections for P1 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir P1-01/DB25-01 34 IOPort None P1-02/DB25-14 35 IOPort None P1-03/DB25-02 36 IOPort None P1-04/DB25-15 37 IOPort None P1-05/DB25-03 38 IOPort None P1-06/DB25-16 39 IOPort None P1-07/DB25-04 40 IOPort None P1-08/DB25-17 41 IOPort None P1-09/DB25-05 42 IOPort None P1-11/DB25-06 43 IOPort None P1-13/DB25-07 44 IOPort None P1-15/DB25-08 45 IOPort None P1-17/DB25-09 46 IOPort None P1-19/DB25-10 47 IOPort None P1-21/DB25-11 48 IOPort None P1-23/DB25-12 49 IOPort None P1-25/DB25-13 50 IOPort None
and now inparticular:
Now does IO 0 get referenced in here(below)? and why are there 4 pins on IO 8 and how are they enabled idividually in the hal file?
# ---PWM Generator signals/setup--- setp [HMOT](CARD0).pwmgen.00.output-type 1 #PWM pin0 setp [HMOT](CARD0).pwmgen.00.offset-mode 1 # offset mode so 50% = 0 setp [HMOT](CARD0).pwmgen.00.scale [JOINT_0]OUTPUT_SCALE net x-output => [HMOT](CARD0).pwmgen.00.value net x-pos-cmd <= joint.0.motor-pos-cmd net x-enable <= joint.0.amp-enable-out # enable first 4 PWMGens on x-enable net x-enable => [HMOT](CARD0).pwmgen.00.enable
5 years 6 months ago #204785 by PCW
The first 4 PWMgens are enabled by PWMGen enable 0 which affects
analog outs 0..3 on TB3 pins 4,8,12,16
5 years 6 months ago #204797 by timfaber
Yeah my bad, will try it again soon
I appreciate all the help I'm getting!!:)
Time to create page: 0.159 seconds
