- Thank you received: 5334
PCW wrote: Getting FF1 right is the first thing,
if FF1 is wrong no amount of fussing with P,I,D will fix it
PCW wrote: 1. If you have forward spindle motion and the velocity is -110 you have the encoder
scale backwards. If you have any feedback (P or I or D terms not 0) you will have a runaway.
2. Encoder velocity is in RPS so -110 RPS is -6600 RPM (there is a encoder RPM velocity pin as well)
3. Can you post your current hal/ini files
