Brother TC-225 Retrofit and Robot integration
5 years 5 months ago #207713 by andypugh
timfaber wrote: And what could be done about the clunky acceleration?
You could try reducing the max_accel number.
Or try putting some numbers in the max_error parameters of the PID to limit the pid output at large errors.
5 years 5 months ago #207743 by timfaber
Now would you say this is reasonably tuned? Don't have enough experience to judge if this will result in decent machining performance.
5 years 5 months ago - 5 years 5 months ago #207744 by PCW
No, you need _much_ more FF1
(or set the OUTPUT_SCALE to mm/s at 10V) and FF1=1.000
If you reduce the OUTPUT_SCALE to an appropriate number (say about 400)
you would need to reduce the PID terms correspondingly (to say P=220 =11000*400/20000)
etc
Last edit: 5 years 5 months ago by PCW.
5 years 5 months ago - 5 years 5 months ago #207745 by bevins
/EDIT Didnt respond to last message. Disregard....
Last edit: 5 years 5 months ago by bevins.
5 years 5 months ago #207748 by andypugh
Assuming a metric machine based on the 136 in the preview, and the suggestion that this isn't a room-sized machine..
In one of the Halscope traces you have have an error of 0.015mm during a move. That's pretty good. But in others it is more like 0.5mm, which is terrible.
5 years 5 months ago #208120 by timfaber
PCW wrote: No, you need _much_ more FF1
etc
Ahh was wondering why my numbers where that high, thought ff1 was in mm/min.
What do you mean by 136 in the preview? The 0.015mm is my bad had the mouse hovering over a lower error value. Basically it is pretty bad. Will post some beter examples of f.error and feed later.
Now in my understanding the way to reduce the f.error is by increasing P, or are there other parameters that infuence it?
Time to create page: 0.283 seconds
