Mini wannabe datron build
2 years 4 months ago #303861 by ihavenofish
A little testing of depth of cut.
29mm deep, 0.3mm step over, 4119mm/m, 36000rpm.
There is a lot of deflection. Some from the cutter, some from the machine, and some from the spindle. Didn't measure but id say at least 0.002" at the bottom of the cut. Picture is after climb, then back conventional, then climb again at 4119mm/m which fully cleaned it up.
I think this is near the practical limit of depth on the prototype machine. I had to cut the end mill shank down to remove any excess stick out. The stock tool was 35mm or so longer and would chatter and deflect a lot on 1/10 the feed. Doesn't chatter now that its shortened.
Can't wait to try some adaptive clearing with this cutter now.
2 years 4 months ago - 2 years 4 months ago #303868 by ihavenofish
Anndd... some 4140HT.
I should have set up the camera, but honestly I thought it would fail.
Anyone making a small machine regardless if its for wood or metal: A quality spindle changes the machine entirely haha. Do not skimp on the spindle.
Last edit: 2 years 4 months ago by ihavenofish.
2 years 4 months ago #303873 by Mr. Mass
Replied by Mr. Mass on topic Mini wannabe datron build
About VFD 1000Hz and more, delta series MS300 and MH300 are available up to 1500Hz. If it is possible to buy used Danfoss 2800 and 2900 series also up to 1000Hz. And so there are many chinese manufacturers, there saw up to 6000Hz.
2 years 4 months ago - 2 years 4 months ago #303875 by ihavenofish
All banned.
Customs will seize them if they find them and you can genuinely go to jail. There's no messing around here.
Also, for clarity these are machines I will sell to customers. So no used items for rando chinese inverters, even if it was legal.
2 years 4 months ago #303877 by ihavenofish
For my next trick: O-1 tool steel (soft).
This is the first proper "sample part" I am going to video to market the new machine. Just waiting on my 4mm end mills to come today or tomorrow I hope.
I expect only one real issue with the fine surfacing on the steel and that is the lack of jerk control and stepper tuning. It will probably leave marks at transitions is my expectation.
2 years 4 months ago #304059 by ihavenofish
Uprights for V1/V2 minimonster. V1 is single drive aluminium base frame, V2 is dual drive, granite base, these uprights can be used for both. As you can see, for this first one I am re-milling out of the old large predator uprights. Not reusing any features, just working around the holes to use it as stock.
I'd already made a Z axis, but I went and changed a few things on it, so I need to make another.
Time to create page: 0.408 seconds
