1 or 2 dedicated 120VAC circuits for my CNC?
3 years 7 months ago #267337 by tommylight
Output
hm2_7i76e.0.7i76.0.0.output-01
is the second pin on the header, not the first
just to be sure
3 years 7 months ago #267342 by Sray69
Yes I have it correct. It is the second pin.
3 years 7 months ago #267357 by tommylight
Use a DVM to measure the voltage change on that pin, if you can.
3 years 7 months ago #267358 by tommylight
3 years 7 months ago #267369 by Sray69
I checked the pins and both pins are triggering in Halshow. Both pins are providing 24VDC when triggered.
Once I reconnected the wires and tested again, the router circuit now works as expected, but the dust collector circuit gives me a "Smart serial card remote error = (27) Over Current" error. I have researched this and I think my problem is that there is no flyback diode on the dust collector relay. Does this sound correct? If yes, can you tell me what diode I need to get and exactly how it should be soldered in?
3 years 7 months ago #267388 by tommylight
If you are getting over current warnings for Mesa outputs, the relay is way out of spec for current draw.
Having said that, any silicium diode will do, something like 1N4001 to 1N4007 will do just fine, wired in parallel to relay winding, just mind the polarity in regard to Mesa output.
I would use another smaller relay in between, or a transistor.
Time to create page: 0.388 seconds
