gww250 wrote: I re-read your posts and on one hand it appears as if you're very familiar with the process of design to code but at other times it appears as if you have never actually used any of the packages you mention
I have been doing basic mechanical design and fabrication for about 15 years now. My last job of about 4 years moved me up into doing CAD design, advanced mechanical design, advanced fabrication, lots of experience on the manual side of the machine shop and some experience running machines.
I have also been involved in making machines for laying up and processing thermoplastic composites. I have also been involved in some of the more basic elements of software and hardware that made those machines run.
Unbelievably CAM was one thing I never did. I asked them many times to get me involved in it but they had higher priorities elsewhere that needed my skills and I never had the time to get into it on my own.
So yeah, I have a lot of experience with everything that surrounds this one gap in my education but this is my first time trying to get familiar with CAM.
gww250 wrote: and you haven't yet told us about the capabilities of you milling machine. A better understanding of what you have will help a lot in understanding exactly what you want as you go forward with your endeavors. What kind of machine do you have first of all and secondly do you need full 3D or just 2.5D code for your projects.
This is exactly what I am trying to figure out right now.
I am learning but still don't fully understand where the line is drawn between 2.5D and 3D and exactly what the capabilities of each are.
A lot of the work I will be doing will be easily accomplished by 2.5D. I want to cut flanges, gaskets and other things that should be quite simple.
On the other hand I don't want to pay for or get familiar with one software that will do that only to find it won't do other things I need.
I feel like I would be best off getting a 3D program off the bat so I'm not limited. I am also quite confident I want to be able to make several different steps in the process. For example face the top of the part, drill or profile cut holes and then 3d machine a shape.
There is however much I don't know and things that I may not know I need or don't need which is why I am here asking for input.
Unfortunately the machine is also something that is greatly up in the air as far as it's capabilities.
I designed it and am currently building it so I won't know for a long time what it's capable of. I am also on a tight budget so for now I am using cheap linear motion and my first attempt will be with an RC brushless motor spindle. From there I will push it's limits and upgrade parts until it can do everything I want it to do.
It is small, about X 400mm x Y 600 x Z 200 travel.
This is very much a concept drawing. The final machine will be very similar but some things may be changed like reinforcing the z axis or other changes.
image missing https://scontent-a-ord.xx.fbcdn.net/hphotos-prn1/t1/21894_449432435092987_1645020437_n.jpg
The frame and gantry are made out of 6" by 2" 1/4" wall steel tube.
image missing https://scontent-a-ord.xx.fbcdn.net/hphotos-ash2/t1/481428_460519023984328_1443850974_n.jpg
I hope to finish the gantry and start assembly next week.
For now I will not be machining it but it is designed so it would be easy to get the base ground, mounting surfaces machined and locating grooves or pads added.
As far as some of the more advanced stuff I can think of right now that I would like to do. That forming die will probably be one of them and is pretty high on my list of things I want to make.
I would also like to be able to machine 4 cylinder head combustion chambers and do other things like that.
Down the road I would like to get something like an a/b axis or even design a fifth axis head or something to expand capabilities further but that would be a ways down the road.
