Let's talk about CAM
12 years 3 months ago #48688 by alan_3301
Replied by alan_3301 on topic Let's talk about CAM
Thanks, I understand that your values may not work for me, just trying to get an idea of how much is reasonable to increase the numbers.
I did find those graphs, and let me see if I have this right
Basically we can shape our V/F "curve" with 3 sets of parameters.
1. pd007 minumum frequency and pd010 minimum voltage
2. pd006 intermediate frequency and pd009 indermediate voltage
3. pd005 maximum frequency and pd008 maximum voltage
I never intent to spin the spindle slower than 4800 rpms, so I will choose 80hz minimum frequency.
So now I play with pd010 minimum voltage until my vfd sends a reasonable amperage while loaded at slow speed?
Then when I figure that out, i set intermediate freq and voltage to approximate a line between my min and max points?
Sound right?
I tried the examples from the graphs of lower torque and higher torque and didn't see much difference.
From the default curve. and example curves, full voltage is sent by 50hz?
How is there anything to gain, amperage wise, if I want more power above 50hz? shouldn't it be maxing out already.
Thanks for your time
10 years 11 months ago - 10 years 10 months ago #65406 by tjmarch
Replied by tjmarch on topic Let's talk about CAM
A update to this item:
# The following items are free,
# DXF2GCODE Cam software
# Open Terminal, copy and paste the each line one at time into Terminal, press enter after each paste.
cd ~
git clone git.code.sf.net/p/dxf2gcode/sourcecode dxf2gcode-sourcecode
cd /home/`whoami`/dxf2gcode-sourcecode/source/
sudo chmod +x /home/`who | cut -d' ' -f1 | sort | uniq`/dxf2gcode-sourcecode/source/dxf2gcode.py
# To run Dxf2gode Cam Software
# Copy and paste the following into Terminal
python /home/`whoami`/dxf2gcode-sourcecode/source/dxf2gcode.py
# To install Sketchup 8 on Ubuntu, Mint or Debian.
# First install Playonlinux on Ubuntu or Mint use the Software install manager for your distro.
# For Debian
# this link for Wheezy
# packages.debian.org/wheezy/playonlinux
# After install of Playonlinux choose install program from within Playonlinux
# then use search function within Playonlinux for google sketchup. Once found choose to install google sketchup. Playonlinux
# will download and install it for you.
# Choose a exe file to start the program, (it will be listed). Icon will be placed on
# your desktop. Program works flawlessly.
# To get Sketch-U-Cam, (CAM add-on) goto web site
# www.openbuilds.com/resources/sketchucam.1/ sign up for login, it is free then download
# Open Sketchup choose menu item Window->Preferences->Extentions->Install Extention
# Choose the Sketch-U-Cam file from the folder you downloaded it to.
# After install of Sketch-U-Cam remember to goto menu item
# Tools-->Phlatboyz-->Options-->Misc Options
# For the line labeled
# Use_compatiable_dialogs set TRUE if you cannot see the parameters dialog
# to TRUE
# CamMill Cam software
# Goto web site
# www.openbuilds.com/resources/cammill-for-windows-linux-mac.149/
# Sign up for login, it is free then download Manual which contains web link to Wiki for install
# # Simple GCODE generators Wiki
# wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple...NC_G-Code_Generators
# 1. Drilling Speeds-n-Feeds
# 2. Arc Generator
# 3. Facing Software
# 4. Bolt Circle Array Software
# 5. Counterbore Software
# 6. Grill Drilling Software
# 7. Bezel Engraving Software
# 8. Text Engraving Software
# 9. Multi-line Text Engraving Software
# 10. Pycam - Drop Cutter Surfacing Software
# 11. Dxf2gcode - import a 2D DXF file and produce G-code
# 12. Rectangular-Circular Pocketing Generator
# 13. Grid Rectangular Circular SpiderNet G-code Generator
# 14. Airfoil G-code Generator 3-4Axis XY-XYUV Foam cuttting (DEAD Link for this one) try this instead www.swarfer.co.za/rc/wire/index.php
# 15. Other G Code Generators
# 16. Using Python scripts with Axis
# 17. Using Python scripts with Windows
# 18. Using Python scripts online
# 19. mGcodeGenerator
# 20. OpenVoronoi and OpenCAMLib
# As for pay for software I have DesignCad v22 with ContourCam Add-on but have not used it yet was very reasonably priced for both pieces of software
Last edit: 10 years 10 months ago by tjmarch.
10 years 11 months ago #65469 by tommylight
Replied by tommylight on topic Let's talk about CAM
also sheetcam, they have a free linux version ( i do not know of limitations, but it works ).
I did install it and it worked once but i never used it.
Regards
Tom
10 years 3 months ago #78249 by remrendes
Replied by remrendes on topic Let's talk about CAM
Hi all!
I'm new in a forum and honestly in a LinuxCNC and in a CAM as well B)
I am looking an simple 2D (from .dxf) CAM software for Linux (or/and Windows). Is the Ddxf2gcode support EMC2? Or is there any better?
And a 3D CAM software for Windows. I have an experience with SW, so I have seen a HSMXpress which is free in SW and a Fusion360.
I think both are Autodesk products and default has a postprocessor for EMC2..
And an other problem, I tried a Vectric Aspire, but when I generated a code, is says a tool changing is not supported. Is it possible to do it?
10 years 3 months ago #78252 by andypugh
Replied by andypugh on topic Let's talk about CAM
remrendes wrote: I am looking an simple 2D (from .dxf) CAM software for Linux (or/and Windows).
www.sheetcam.com/downloads
[quite]Is the Ddxf2gcode support EMC2? Or is there any better?[/quote]
sourceforge.net/projects/dxf2gcode/
Says is supports EMC2 (which means LinuxCNC now). I think you can even set it up as an input filter:
linuxcnc.org/docs/2.7/html/config/ini-co...html#_filter_section
Autodesk are making quite a good job of squeezing everyone else out of the market with Fusion360, it's hard to resist the combination of features and the price.
10 years 3 months ago #78254 by remrendes
Thanks Andy!
I had a quick look on the internet and a Sheetcam looks enough for generate a G code from dxf into a LinuxCNC.
I hope I can found some tutorials.
Yes, a Fusion360 looks pretty cool for free. I don't want to change the SW, but for a hobby CAM I think I won't find better.
Time to create page: 0.109 seconds
