Let's talk about CAM
10 years 2 months ago #78345 by remrendes
Replied by remrendes on topic Let's talk about CAM
It works great! Thanks again!
Which is the best process to change a tools by manual not with the M6 code?
Now I generate the code with the ATC, but I have not got a changer.
10 years 2 months ago #78346 by andypugh
Replied by andypugh on topic Let's talk about CAM
remrendes wrote: It works great! Thanks again!
Which is the best process to change a tools by manual not with the M6 code? .
You would still use M6, even without a toolchanger.
Does your machine have consistent-length tools where each tool is the same length each time it is inserted? If so then you can use hal_manualtoolchange
If your system requires you to re-measure the tool length after each tool-change you might actually find it more convenient to create G-code on a 1-tool-per-file basis.
10 years 2 months ago #78357 by tarasko
Replied by tarasko on topic Let's talk about CAM
yoshimitsuspeed wrote: What are other options?
Try Blendercam!
10 years 2 months ago #78361 by tommylight
Replied by tommylight on topic Let's talk about CAM
Try Blendercam!
+1
Do give it a try, it will look different, but it is very capable.
10 years 2 months ago #78364 by remrendes
Hi Andy!
I need to re-measure the tools.
So can I re measure a tool while the program is running?
10 years 2 months ago #78365 by andypugh
remrendes wrote: So can I re measure a tool while the program is running?
The simple answer is "No"
The more complicated answer is "Yes, but it takes some reconfiguration and you need a tool-length measurement switch"
With a non-repeatable toolholder it is likely to be generally easier to run one file per tool. Even for making multiple parts it is likely to be easier to swap the parts than the tool, and do the same operation on all parts and then change tool and do the second op with a second file.
If you fancy using a tool-length measurment switch, try running the sim/axis/remap/manual-toolchange-with-tool-length-switch sample configuration. (Don't worry, it won't attempt to operate your hardware)
The following user(s) said Thank You: remrendes
Time to create page: 0.493 seconds
