Limit to number of tools in tool table
jtc wrote: for what I see, that concept it's not intended to use with lathes... please don't forget about lathes.
Not so, it is entirely applicable to lathes, even dual-spindle lathes with two carousels, if need be.
I am much more a lathe user than a mill user, I will not be forgetting lathes.
andypugh wrote:
NitroCH3NO2 wrote: I vote for this also.
It's all very well voting for it, but I am not sure that it works properly, as it is just a proof of concept.
The version there uses a database structure that is nowhere near as flexible as it could be. I really think that the database should look like this:
wiki.linuxcnc.org/cgi-bin/wiki.pl?ToolDatabase
But _look_ like the current one from the point of view of the tool editor.
(which needs to be changed to work with a database).
I've done a lot of work with Python using databases so if you need some help in that area I'm in.
JT
- LearningLinuxCNC
- Topic Author
- Thank you received: 39
I have never used GIT before though. That is something that I am trying to figure out.
I also need to figure out how to do a run in place configuration for testing purposes.
NitroCH3NO2 wrote: I am glad to help with testing of this. If I can help with programming I can do that also. Relatively new to python but I have coded in VB, VB.net, C, C++, Fortran ......... Not an expert but I might be able to help. I have also done quite a bit of work on database stuff.
see if this tutorial it's suitable for you.
www.wiki.eusurplus.com/index.php?title=LinuxCNC_Run_In_Place
João
JT
The tooleditor I think you are referring to is written in TCL ...uggg
But the GladeVCP one is written in python (and can run stand alone too) I can modify that one for you.
(when I'm back from working away that is)
