- Thank you received: 39
Limit to number of tools in tool table
7 years 11 months ago - 7 years 11 months ago #120935
by nkp
Replied by nkp on topic Limit to number of tools in tool table
checked the changes from here
github.com/LinuxCNC/linuxcnc/issues/411
but this is a very short and simple test))
Has anyone already tried this at work?
ps
large_tool_file_generator:
gist.github.com/nkp216/6b7212d09cb696c9478cb7668e239984
ps
Last edit: 7 years 11 months ago by nkp.
6 years 8 months ago #158328
by 3D-Master
Replied by 3D-Master on topic Limit to number of tools in tool table
one thing that i would really appreciate is to define a tool as a touch probe. This way the tool will be only allowed to rotate when orienting the spindle. M3/M4 commands will be ignored. Also the maximum feedrate should be limited to a definable value.
Other useful parameters would be:
Tool edge radius (0 or more, float)
Delta length (extra tool length offset - negative, 0 or positive - float)
Delta radius (extra tool radius offset - negative, 0 or positive - float)
Delta edge radius (extra tool edge radius offset - negative, 0 or positive - float)
orienting angle (0-359.999 - float)
Tool locked (used with breakage detection - 0 or 1)
number of cutting edges (0 or positive)
length offset and radius offset (for measuring length and radius - negative, 0 or positive - float)
lbreak and rbreak (for tool breakage detection - negative, 0 or positive - float)
Nmax (maximum rotation speed - 0 or positive)
and maybe to be allowed to define tools like this: T1.1 (still the same physical tool but other definitions)
my wishlist
my wishlist
6 years 8 months ago #158336
Replied by cmorley on topic Limit to number of tools in tool table
There was some work on using a database for the tool table.
This would allow arbitrary info to be added to the tooltable.
This would be a first step to what you want.
Andy started it but got discouraged by lack of support IIRC.
Chris
Chris
6 years 8 months ago #158393
Replied by andypugh on topic Limit to number of tools in tool table
Max speed would seem like a very sensible thing to have in a base tool database, rather than a custom entry.
To avoid this:
(And another I saw but can't now find where a fly-cutter went through the cabinet and two walls)
To avoid this:
6 years 8 months ago #158394
Added to
wiki.linuxcnc.org/cgi-bin/wiki.pl?ToolDatabase
(but does it really belong in the "tool" category?)
6 years 8 months ago #158396
by 3D-Master
yes, at least what i know Heidenhain does this. This prevents the tool to go above the set max-rpm when automatically calculating the rpm based on the tool diameter and cutting speed (VC in Metric and SFM in Imperial)
Time to create page: 0.285 seconds
