- Thank you received: 39
Limit to number of tools in tool table
- LearningLinuxCNC
- Topic Author
11 years 1 month ago #62343
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Limit to number of tools in tool table
I vote for this also.
11 years 1 month ago #62345
by jtc
I have reached the 56 tools limit on 2 machines, and that is simply annoying :side:
And when this limit was reached, find that the number of tools in the tool table is the problem it's kind of difficult, linuxcnc don“t even starts so the tool table has to be edited manually.
My vote is for a SQL database solution, that permits some flexibility on the future. Some triggers that update automatically the tools offsets if changed on the database should be great.
Replied by jtc on topic Limit to number of tools in tool table
andypugh wrote:
NitroCH3NO2 wrote: Does anyone know the reason behind the limit of 56 tools in the table?
Yes, the tool data is passed around between the different modules in a fixed size structure that only has room for 56 tools.
It's crazy, and I actually did a lot of work to fix it and put the tool data in an SQL database. But it was widely ignored.
it's the andypugh/tooltable branch here: git.linuxcnc.org/gitweb?p=linuxcnc.git;a=heads
11 years 1 month ago #62346
by BigJohnT
Commit it to master so it can get some testing. People using master expect it to break from time to time.
JT
Replied by BigJohnT on topic Limit to number of tools in tool table
JT
11 years 1 month ago #62347
Replied by cmorley on topic Limit to number of tools in tool table
Andy:
When i get no response such as you did - I take it as a go-ahead.
I announce that i'm going to add it to master unless i hear a good reason not too.
and after that I will commit it to master. once it's in master if there is a real reason not to have it there,
devs will be more forward.
It has happened a few times for me and wasn't negative.
And I vote for your work on tool table too.
and for JA branch
In fact I think we should peel off a 2.8 branch off master now then add JA right away.
It's the only way it will get added any time reasonable.
IMHO
Chris M
and for JA branch
IMHO
Chris M
The following user(s) said Thank You: BigJohnT
11 years 1 month ago #62348
It's all very well voting for it, but I am not sure that it works properly, as it is just a proof of concept.
The version there uses a database structure that is nowhere near as flexible as it could be. I really think that the database should look like this:
wiki.linuxcnc.org/cgi-bin/wiki.pl?ToolDatabase
But _look_ like the current one from the point of view of the tool editor.
(which needs to be changed to work with a database).
Replied by andypugh on topic Limit to number of tools in tool table
NitroCH3NO2 wrote: I vote for this also.
11 years 1 month ago #62349
by jtc
for what I see, that concept it's not intended to use with lathes... please don't forget about lathes.
Time to create page: 0.216 seconds
