- Thank you received: 2100
hello hmnijp,
could you please elaborate on that?
I have tryed to comment out this section of the code in interp_arc.cc and then make the build, but I still get error message.
Code:CHKS((abs_err > spiral_abs_tolerance * 100.0) || (rel_err > spiral_rel_tolerance && abs_err > spiral_abs_tolerance), _("Radius to end of arc differs from radius to start: " "start=(%c%.4f,%c%.4f) center=(%c%.4f,%c%.4f) end=(%c%.4f,%c%.4f) " "r1=%.4f r2=%.4f abs_err=%.4g rel_err=%.4f%%"), a, current_x, b, current_y, a, *center_x, b, *center_y, a, end_x, b, end_y, radius, radius2, abs_err, rel_err*100);
