spindle with encoder
1 year 6 months ago #326637 by JohnnyCNC
Replied by JohnnyCNC on topic spindle with encoder
The index signal sent to the encoder input to LCNC must be 1:1 with the spindle. My encoder is on my motor. But, I get the index signal from the sensor on my spindle. If the gearing of the motor to the spindle was exactly 1:1 you could attached the encoder to either the motor or spindle. But if the gearing is anything other than 1:1 you must get the index signal from the spindle. My gearing is 1:1.8 and the A/B encoder signals come from the motor side, but my Z (index) signal comes from the spindle side.
The following user(s) said Thank You: tommylight, vre
1 year 6 months ago #326801 by vre
Replied by vre on topic spindle with encoder
So i must attach encoder of encoder disk to spindle shaft because all other places
i can mount the encoder are not 1:1 gear ratio with spindle shaft.
1 year 6 months ago #326810 by vre
To mechanically adjust the exact same ratio is very difficult
Also with counter chips division maybe can not be integer multiple
so the only real option is to mount and aluminum disk to spindle shaft
and because my spindle shaft from top has the hydraulic cylinder that locks the tool
the only place can put this is only to the downside of spindle shaft.
How many lines must have the disc for rigid tapping ?
Also must have disc with A B and Z signals or only A is enough ?
1 year 6 months ago #326827 by andypugh
Replied by andypugh on topic spindle with encoder
You can't do multi-pass threading (lathe, or peck-rigid) if the index isn't 1:1 with the actual spindle.
But, for single-pass rigid tapping it doesn't matter where the index is as long a the encoder scale accounts for the gearing.
1 year 6 months ago #326828 by andypugh
Also, it is perfectly possible to have the index and A/B phases on different shafts. A prox sensor picking up a keyway / bolt whatever on the spindle can work fine.
The following user(s) said Thank You: vre
1 year 6 months ago #326837 by vre
For rigid tapping i need only index signal from spindle shaft
A-B signals can come from elsewhere the encoder is mounted that is not 1:1 ratio correct ?
Time to create page: 0.159 seconds
