spindle with encoder
1 year 6 months ago #327101 by PCW
Replied by PCW on topic spindle with encoder
I think maybe you don't understand how rigid tapping works.
When rigid tapping, the Z axis motion is synchronized (geared basically)
to the spindle rotation, the synchronized motion is continuous through
the downstroke, spindle reversal and upstroke. Any pause that interferes
with this "gearing" will break taps.
1 year 6 months ago #327128 by vre
Replied by vre on topic spindle with encoder
rigid tapping needs reversal of spindle so backlash matters.
If i have encoder on spindle shaft backlash
will be problem?
How many lines encoder needed for rigid tapping?
1 year 6 months ago #327222 by vre
Why if i put in spindle shaft an aluminum disk with 2x100 holes(pi/2 equally spaced for A-B) and 1 hole for index drilled on the same mill?
I think i can do holes 1-1.5mm in the same mill accurately.
1 year 6 months ago - 1 year 6 months ago #327223 by PCW
Typically you just have one track of holes and the B detector offset from the A detector by
hole_pitch*(N+1/4). That is, if the holes were 2 mm apart, the A/B detectors would be
spaced .50 MM or 2.50 mm or 4.50 mm etc.
This 1/4 pitch offset gives you the desired 90 degree phase difference between A and B.
Note the when drilling holes you should aim for a 50% duty cycle waveform
on A and B. This may require some experimentation and changing  the sensors
radial positions.
Last edit: 1 year 6 months ago by PCW.
1 year 5 months ago #327538 by andypugh
Replied by andypugh on topic spindle with encoder
A workaround if you are worried about phase error on reversal is to use a tension-comopression tap holder to absorb the axial mismatch.
1 year 5 months ago #327762 by vre
I found this app to do the design so can cut this with laser
Time to create page: 0.248 seconds
