Actual position and Commanded position differ, using cia402 [SOLVED]
1 year 5 months ago #328800
Replied by andypugh on topic Actual position and Commanded position differ, using cia402
I don't know why there is a 22.2222 factor on your rotary axes, it feels like that constant factor could be in the INI scaling.
In fact your userkins appears to basically be a trivial kinematics? Why not use trivkins?
Maybe you are running a run-in-place system, so LinuxCNC is running from linuxcnc-dev but halcompile is placing the compiled kins in the root structure?
(But that wouldn't explain why edirting the C and recompiling works...)
The following user(s) said Thank You: low-blip
1 year 5 months ago #328815
by low-blip
Replied by low-blip on topic Actual position and Commanded position differ, using cia402
I am so confused. the setup does still works after I deleted userkins.c, so the problem must have come from the old userkins.so. According to our git history, userkins.comp never changed, and we did run halcompile when we set up the project, so I don't see why userkins.so changed. Not important, maybe someone accidentally copied an older version from somewhere.
As for the other issues with userkins, I don't know, this is how I received the configuration. I'm slowly trying to figure things out.
1 year 5 months ago #328816
by low-blip
I've learned C for a semester in university, didn't get it at all. It was so not nice to me.
I do program Arduinoes these days, because the other colleagues don't want to, but isn't that C++? Any way I hate it too
When I need C I use Rust instead, it's a pain too but at least I can usually figure out where I made a mistake. Which is usually forgetting the ';'
Time to create page: 0.049 seconds
