- Thank you received: 2177
Actual position and Commanded position differ, using cia402 [SOLVED]
1 year 5 months ago #328741
I agree, this is most likely a problem with your custom kinematic module. I usually see these kinds of jumps when the forward and the inverse kinematics do not match up.
Replied by Aciera on topic Actual position and Commanded position differ, using cia402
I see you have a userkins module, that one becomes suspicious of course.
The following user(s) said Thank You: low-blip
1 year 5 months ago - 1 year 5 months ago #328745
by low-blip
Replied by low-blip on topic Actual position and Commanded position differ, using cia402
I checked the userkins.comp file, found nothing strange, but in userkins.c, it was
while in userkins.comp or either of the kinematicsInverse functions, the /80 was not there. I tried compiling again, nothing changed. I tried deleting the /80 from userkins.c, everything is now working. I just have no idea why..int kinematicsForward ...
pos->tran.x = j[0]/80; // X coordinate
pos->tran.y = j[1]/80; // Y coordinate
pos->tran.z = j[2]/80; // Z coordinate
Last edit: 1 year 5 months ago by low-blip.
The following user(s) said Thank You: Hakan
1 year 5 months ago #328787
by low-blip
Could be, but I can't figure out where it's coming from, so looks like I'm stuck with a temporary fix of a possible temporary fix for now.
I remember Python giving me so much grief over the tabs and spaces in my first year of learning to program! At least these days IDEs take care of that problem.
C just went completely over my head when I tried to learn it. I can mostly read it but I cannot write anything in C, it's pretty frustrating
1 year 5 months ago #328789
Sounds like a problem compiling the .comp file as the 'halcompile' tool would not add or remove anything in those lines.
Impossible to say without actually seeing your userkins.comp file.
1 year 5 months ago #328790
by low-blip
Oh thanks! you're right that halcompile is having some problem, userkins.c is unchanged after I run
. There's nothing in the terminal that hints at it not working.
I've attached the userkins.comp file here
sudo halcompile --install userkins.comp
Compiling realtime userkins.c
Linking userkins.so
cp userkins.so /usr/lib/linuxcnc/modules/
1 year 5 months ago #328799
I think you are being confused by an old version of 'userkins.c'. Note that
will not create a 'userkins.c' file at all, it will directly create a 'userkins.so' and copy that to the appropriate folder.
linuxcnc.org/docs/html/man/man1/halcompile.1.html
If things are working after
'sudo halcompile --install userkins.comp'
then you can delete the 'userkins.c' file.
