After install I get applet removal error prompts
If you have not copied them over to /home/yourdir/emc2/configs then you can find them at /usr/share/doc/emc2/examples/sample-configsIf not find the config file axis.ini (or axis_mm.ini) change the entry in the [DISPLAY] section DISPLAY = AXIS to DISPLAY = xemc
Sounds like openGL, you often get a black circle or square or sometimes the graphic rendering just disintegrates into a mess of coloured lines half way down the window.the cursor was a black arrow and I couldn't click on anything anywhere on the screen
xemc does not use openGL, so if it runs OK that pretty much confirms the problem
The link to switching to software openGL is here
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl...oftware_based_OpenGL
NEVER MIND! I reburned the CD at a lower write speed and the install went through without a hitch.
After running the Latency Test for two days, I can't get anything above 15.7usec in their category, so I'm going to let that slide for now. If it proves to be a problem in the future, then I'll address it or replace the machine.
I received a config file from Probotix for running the 3-axis box I have, so I installed it (after setting permissions with "sudo chmod o=rwx sample-configs".
I tried running EMC2, but it locks up, so I changed DISPLAY=AXIS to DISPLAY=XEMC, per ArcEye's suggestion above. Now, XEMC runs but it doesn't seem to run 'completely'. Here's what's happening:
XEMC starts okay, and when I power on the 3-axis box, the three axes and their position numbers in the middle of the screen turn from green to red, indicating power, I think. So I think we're getting close to success!
However, I can't get the ESTOP button onscreen to change from "ESTOP" to anything else (such as "ESTOP OFF"?) when I click and hold on it and select STOP OFF. Also, I tried setting the mode from AUTO to MANUAL and also tried MDI, each time trying to type "G1 x3" into the MDI field to manually jog the x-axis motor I plugged in. The motor ignores me, but it's getting power because it locks in position and I can't spin it when the power is on. XEMC locks up and ignores me, although it will allow me to try clicking ESTOP, ABORT, and to access the drop-down menus. The MDI field is locked. Note: The PROGRAM buttons below, to open a file to run, is greyed out and inaccessible all the time (never active).
Ideas? I'm trying to attach a screenshot to this forum reply, but the Add File function isn't working for me (using different computer than XEMC system). I can browse and select the file, click Open, and then nothing... Tried it three times.
I don't understand why you had to change the permissions of sample-configs?
If you installed from a liveCD simply copy your config directory to /home/~/linuxcnc/configs and run with linuxcnc path/to/your/config.
Can you run the Axis Sim?
also if limit switches are shown in the hal file and not connected would also give similar problems .
it's normal for the machine to be homed first before other functions become usable .. i.e greyd out
so i am suspect at the moment of the hal files you have requiring estop and limits , which you may not have connected up
which would then not allow you to continue .
along with your graphics problem which is not helping ..
Hmmm. Yes, nothing is connected except the 3-axis box via parallel port, all the power cables, one USB cable from the 3-axis box to the computer (which I can't recall why it's there) and one stepper to the x-axis output. My mill is still out in the garage (not yet converted with the CNCFusion kit I have). No ESTOP wiring. Actually, I don't yet even have a breakout board so that I can highjack the parallel port wiring for it.
I put the config folder in with the other ones in "/usr/share/doc/examples/sample-configs". It appeared upon starting EMC2 as one of the choices in the long tree of various configurations. Should I be aiming some pointer ina file to some other place that only has my one config folder, such as "/home/~/linuxcnc/configs" as BigJohnT mentioned?
Haven't tried the Axis sim yet. Please correct me if I'm about to do the wrong thing, but to run Axis Sim, I should: (1) set DISPLAY=AXIS instead of XEMC, then (2) when I launch EMC2 and see all the various configs, I select the one called "Sim", then (3) say "wow, this is new..." and report back about what's so new... I'm not sure what I'm looking for or what do inside Sim, but if I see a crash, or it locks up, then I guess that's the answer you're looking for, else I guess I can simulate moving the axes around and see if the numbers change as if there's a machine attached.
I'll go try it now and report back in about 30 minutes. Thanks all!
I selected sim/axis.ini which launches the xemc display instead of the Axis display. Played around. It responds to simulated homing (x and y) and I see the numbers change simulating an axis slowly moving, but then complains when I try to home z because (it says) of the shared homing switch. It also won't run the simple g-code command "g1 x1" (it kinda locks up for a few seconds before returning control - the MDI field where commands can be entered looks mucked up with inverse character fonts while it's locked).
Then, I edited the axis.ini file (which had "DISPLAY=XEMC") to DISPLAY=AXIS. When I launched it again, it just locks up. The EMC2 splash screen with the penguin remains over the top of the Axis window and I can't click on anything (cursor turns to a black arrow and is stuck that way).Only manually powering down the system with the switch on the front panel gets the system's attention.
I can email you or upload the .ini and .hal files I was sent for my mill if you want to see them. Too bad the Add File command is out of order today.
which verson of linuxcnc are you using ?
by all means email me your configs and i'll check them over
Some additional background details can be found in my earlier posts in this thread. Long story short: I'm running an Optiplex GX240 desktop system with a separate graphics card. Had to use Linux 8 because 10 gave install errors, as is shown above in the postings.
I'm emailing you the zipped config folder now. Hope you can catch my setup problem. One piece of added info that may prove helpful: The config files they sent me were originally used on an X3 at the place where I bought the used hardeware/ballscrews. It worked on their machine, but obviously has switches and pin assignments for THAT machine, not the 'no machine' situation the controller sees in my office at the moment (I haven't tried installing the hardware and motors on my X3 yet). I believe there are config lines designed to look for switches that don't exist anymore and that is causing the software to halt. I'm not savvy enough yet to safely edit those lines out on my own, though.
Thanks for your help!
it does appear if your struggling running the sim apps , that either your install is bad , or the pc is just not up to it ,
if you get a chance see if you can take a screenshot if it allows , and see if we can pin it down .
you'll need a pc with at least 2gig of memory to be safe , although it will run on 1gig , it can be a pain
if you have try'd to install with less memory than 2gig , the chances are it would have given a corrupt install
i'd sort out the pc first before embarking on linuxcnc , it could give you a false impression of being sane
