Going round in circles again
LinuxCNC - Enhanced Machine Controller #
# LinuxCNC is a software system for computer control of machine #
# tools such as milling machines. LinuxCNC is released under the #
# GPL. Check out
www.linuxcnc.org/
for more details. #
# It seems that ./configure completed successfully. #
# This means that RT is properly installed #
# If things don't work check config.log for errors & warnings #
# Next compile by typing #
# make #
# sudo make setuid #
# (if realtime behavior and hardware access are required) #
# Before running the software, set the environment: #
# . (top dir)/scripts/rip-environment #
# To run the software type #
# linuxcnc #
hamish@hamish-Presario-CQ57-Notebook-PC ~/linuxcnc-dev/src $ make
Reading 62/192 dependency files
Done reading dependencies
Reading 0/198 realtime dependency files
Done reading realtime dependencies
Compiling hal/user_comps/mb2hal/mb2hal.c
Compiling hal/user_comps/mb2hal/mb2hal_init.c
Compiling hal/user_comps/mb2hal/mb2hal_modbus.c
Compiling hal/user_comps/mb2hal/mb2hal_hal.c
Linking mb2hal
make: yapps: Command not found
hal/utils/Submakefile:101: recipe for target 'objects/hal/utils/halcompile.py' failed
make: *** [objects/hal/utils/halcompile.py] Error 127
hamish@hamish-Presario-CQ57-Notebook-PC ~/linuxcnc-dev/src $ sudo make setuid
chown root ../bin/rtapi_app
chmod 4750 ../bin/rtapi_app
chown root ../bin/linuxcnc_module_helper
chown: cannot access '../bin/linuxcnc_module_helper': No such file or directory
Makefile:483: recipe for target 'setuid' failed
make: *** [setuid] Error 1
