Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
8 years 8 months ago #106130 by rodw
Always a good idea to walk away sometimes.
There is an error here
make: yapps: Command not found hal/utils/Submakefile:101: recipe for target 'objects/hal/utils/halcompile.py' failed make: *** [objects/hal/utils/halcompile.py] Error 127
This Yapps thing is a new dependency and I've just seen a couple of comments about it being a problem. Just click on the install button on this page and follow your nose
community.linuxmint.com/software/view/yapps2-runtime
Then rerun make
The following user(s) said Thank You: shortcircuit48
8 years 8 months ago #106141 by shortcircuit48
I may be doing this incorrectly
hamish@hamish-Presario-CQ57-Notebook-PC ~ $ cd /home/hamish/linuxcnc-dev
hamish@hamish-Presario-CQ57-Notebook-PC ~/linuxcnc-dev $ cd debian hamish@hamish-Presario-CQ57-Notebook-PC ~/linuxcnc-dev/debian $ dpkg-checkbuilddeps
dpkg-checkbuilddeps: error: cannot read debian/control: No such file or directory
hamish@hamish-Presario-CQ57-Notebook-PC ~/linuxcnc-dev/debian $ cd /home/hamish/linuxcnc-dev
hamish@hamish-Presario-CQ57-Notebook-PC ~/linuxcnc-dev $ dpkg-checkbuilddepsdpkg-checkbuilddeps: error: cannot read debian/control: No such file or directory
8 years 8 months ago - 8 years 8 months ago #106144 by cncnoob1979
You first have to configure linuxcnc. Then you can run the check dependencies. Go back one step.
cd linuxcnc-dev
cd debian
./configure uspace
cd ..
dpkg-checkbuilddeps
Last edit: 8 years 8 months ago by cncnoob1979.
8 years 8 months ago #106145 by shortcircuit48
Hello and thanks as suggested
hamish@hamish-Presario-CQ57-Notebook-PC ~ $ cd /home/hamish/linuxcnc-devhamish@hamish-Presario-CQ57-Notebook-PC ~/linuxcnc-dev $ cd debian hamish@hamish-Presario-CQ57-Notebook-PC ~/linuxcnc-dev/debian $ ./configure uspace
Package libxenomai-dev exists, but information about its source package
is not available. This most likely means that you do not have the
right deb-src lines in /etc/apt, or that you need to "apt-get update".
hamish@hamish-Presario-CQ57-Notebook-PC ~/linuxcnc-dev/debian $ cd ..
8 years 8 months ago #106148 by cncnoob1979
You have to enable source code repositories as stated in the how to. Are you following any of the guides?
Excerpt from post 1&2
NOTE: You need to enable source repositories and apt-get update for the next steps using ./configure uspace. If you do not you will not be able to complete this step. Package Manager>Settings>Repositories> Check Mark - Enable Source Code Repositories.
8 years 8 months ago #106151 by shortcircuit48
Sorry, I must have missed checking that box, where is it?
Do I run this again as when I do it indicates multiple occurrences
sudo add-apt-repository 'deb mirrors.kernel.org/ubuntu precise main universe'
sudo apt-get update
sudo apt-get install libgnomeprintui2.2-dev python-support tcl8.4-dev tk8.4-dev
