Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
8 years 7 months ago #107370 by bkt
For first thanks for your work ...
I do not always follow the forum or mailing list so I completely lost my progress on ubuntu / mint 64bit and RTAI. .... The 4.x kernel version that you say about Kuminzky corresponds to the RTAI 5.1 version + adaptations made by kuminzky for LCNC? In any case, despite being a version dev. does he work on a real robot (scara / puma / delta) or is it just sim?
I wrote here because my question on mailing list is missing.
giorgio
8 years 6 months ago #108460 by cromaglious
Anyone run into this as well? Any ideas? XmuLookupStandardColormap error
Linux vescnc 4.14.18-rt15 #1 SMP PREEMPT RT Wed Feb 14 14:11:27 PST 2018 x86_64 x86_64 x86_64 GNU/Linux
Mint 18.1
model name : AMD GX-415GA SOC with Radeon(tm) HD Graphics
quad core
8GB RAM 2TB HD Dell Wyse Thin client Zx0Q Ethernet + Wifi -- no parallel Looking to run with 7i92M + 7i76 X1
EDIT ADDED IN FROM THE START OF THE COMMAND LINE:
ves@vescnc ~/linuxcnc-dev/debian $ linuxcnc
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/ves/linuxcnc-dev/configs/sim/axis'
Machine configuration file is 'axis.ini'
Starting LinuxCNC...
Found file(lib): /home/ves/linuxcnc-dev/lib/hallib/core_sim.hal
Note: Using POSIX realtime
Found file(lib): /home/ves/linuxcnc-dev/lib/hallib/sim_spindle_encoder.hal
Found file(lib): /home/ves/linuxcnc-dev/lib/hallib/axis_manualtoolchange.hal
Found file(lib): /home/ves/linuxcnc-dev/lib/hallib/simulated_home.hal
Found file(lib): /home/ves/linuxcnc-dev/lib/hallib/check_xyz_constraints.hal
File "/home/ves/linuxcnc-dev/bin/axis", line 60, in <module>
from rs274.OpenGLTk import *
File "/home/ves/linuxcnc-dev/lib/python/rs274/OpenGLTk.py", line 17, in <module>
import _togl
ImportError: /home/ves/linuxcnc-dev/lib/python/_togl.so: undefined symbol: XmuLookupStandardColormap
link (updating variable file): No such file or directory
task: 573 cycles, min=0.000042, max=0.002076, avg=0.001050, 0 latency excursions (> 10x expected cycle time of 0.001000s)
8 years 6 months ago #108637 by cncnoob1979
K-1,
I don't know if he is running a robot or not. Sorry maybe someone else can chime in and tell us.
cromagilous,
Did you have any missing dependencies?
Is this the latest master version? Looks like you are running a sim Hal. But you are in realtime so at lest the kernel is good.
Have you tried looking at the last import .hal before the error?
8 years 6 months ago #108866 by dbanks
My entering of the long code at post 4 rendered being unable to locate Tcl18.6-dev, tk8.6-dev. First line of the Kernel install wget resulted in unable to resolve host address. Didn't try the patch following given that not working. Couldn't continue from there, assuming it all stacked on itself. Any ideas?
  • ozzyrob
  • New Member
  • New Member
8 years 6 months ago #108868 by ozzyrob
If you are having trouble in ubuntu 16.04 finding packages it is best to use aptitude and do a search
tcl8.6-dev & tk8.6-dev are listed & current for ubuntu 16.04
You can use this page to search for packages
packages.ubuntu.com/
  • ozzyrob
  • New Member
  • New Member
8 years 6 months ago #108869 by ozzyrob
ftp://ftp.kernel.org has changed to www.kernel.org
The linux kernel sources have been moved from ftp servers to http servers. It happened a few months ago and probably slipped the notice of many useres.
Time to create page: 0.251 seconds
