Hi Martin
About "my variable names are short ENA" , keep PARAM_ENA and all PARAMS short but give them a significant name like "Enable" that will display in the tree. A line of code must be <256 characters but the display is not limited
About Inkscape, I agree it is not really fun to learn a new app just for an icon. But if you want to try it, open icons.sgv, select one icon then ungroup to see all the components they are made of. And yes it is not at all like GIMP. I made a few but I still need some. What is interesting by copying and editing is they match with the others. I hope some day someone else is willing to create more.
About 'cutting-params and diameter', look at my screenshot showing all kind of lines, the top one. Far right is a rectangle where I set tool diameter compensation. The outside line are what the final cut will leave and the inner lines are the tool path. Same for the circle (far left) which is based on helix. So when I want a rectangle 10X20, this is the size I set, I do not have to calculate tool diameter. I agree that code is written once but what is interesting with tool compensation is that it will follow any line correctly. You have to do the tool change first.
I do not have a tool changer and am writing code for using my probe to reset Z position like in those videos
and my probe is this one
www.micro-machine-shop.com/3D_digitizing.htm
110 USD from
wildhorse-innovations.com/index.php?_a=viewProd&productId=80
I will look to modify the code to use same "menu.xml" for menu or icon view interface
Regards
Fern
