That is correct, if you leave the Z axis values, it will still work properly, but it will wait for the Z axis movement to finish. That means it will take longer to cut a plate of metal, mush longer when doing a lot of small parts.snugglylovemuffin wrote: Yeah the Toma system is supposed to work entirely off an M3 command, so I did edit the gcode tools window. I'll get back to it and report findings.
