Downdraft design questions
5 years 10 months ago #193067 by txtrone
Replied by txtrone on topic Downdraft design questions
rodw wrote: discrete diode
Discrete?
5 years 10 months ago #193068 by rodw
Replied by rodw on topic Downdraft design questions
Yup, that will do. Typically, the diodes most used are the IN4004 or IN4007 etc. The last digit I think sets the voltage tolerance but it does not really matter if its rated for 50 volts or 1000 volts. (My take anyway). A diode is like a one way check valve in plumbing
The following user(s) said Thank You: txtrone
5 years 10 months ago #193069 by txtrone
rodw wrote: Yup, that will do. Typically, the diodes most used are the IN4004 or IN4007 etc.
I had to use a magnifier, but these are 1N4007. How does this look?
5 years 10 months ago #193071 by rodw
Looks great, hope I got them the right way round. PCW will confirm If I stuff up to be sure.
5 years 10 months ago - 5 years 10 months ago #193076 by Aciera
Replied by Aciera on topic Downdraft design questions
From the manual:
Note: When W1 is in the default left hand position, VIN is connected to VFIELD, so only VFIELD need be supplied to the 7I76E to power its field IO.
VINpower runs the field I/O processor and normally is connected to field power. VIN must be greater than 8V for proper operation. This means VIN must come from a separate source if 5V field voltage is used
If W1 is in the left position, connection of TB1 Pin5 (VIN) to the same 24V supply is not _necessary_ since it is already connected.
Since I am sure a LOT of people have used Norbert's schematic it doesn't seem to cause much harm to do it that way though.
[edit]
I'm sure my first machine is still wired that way.
Last edit: 5 years 10 months ago by Aciera.
5 years 10 months ago - 5 years 10 months ago #193078 by rodw
[edit]
Man, he released that just after I got my card wired up!
And the 7i76e was not supported by pncconf then so it was all manual building hal and ini.
Last edit: 5 years 10 months ago by rodw.
Time to create page: 0.243 seconds
