Exactly.Use Kevlar reinforced belts instead of steel ones.
Too long ago but I think it might have been steel for the torque required or the supplier did not offer kevlar. Not a lot of choice in the colonies..Use Kevlar reinforced belts instead of steel ones.
The moment on the rails depends only on where the force is applied relative to the rails, it does not depend on what the load path is between the two.
It is cheaper and simpler to install, but I am worried about geometry issues that this solution could cause.
