- Thank you received: 907
RS485 For Hypertherms
- snowgoer540
phillc54 wrote:
snowgoer540 wrote:
phillc54 wrote:
Your links were still pointing to the installed version?snowgoer540 wrote: Ok, starting to get it. But how come when I uninstalled the installed version of Linuxcnc it all blew up and stopped working?
Probably yes. And I couldn’t find pncconf. Well I found it, but running it didn’t do anything.
Did you run rip-environment before hand and did you run pncconf from the same terminal session?
If you answer yes to both then I have no idea...
In all honesty Id be relatively sure I ran them from different sessions. I had no idea it only lasted one session. Now I want to try it again...
- snowgoer540
In all honesty Id be relatively sure I ran them from different sessions. I had no idea it only lasted one session. Now I want to try it again...Code:$ source ~/linuxcnc-dev/scripts/rip-environment $ pncconf
Yep that worked great! Thanks for taking the time to spell this out for me. It really helped me understand what's going on.
- snowgoer540
phillc54 wrote:
Let me know how it goes.Actually, it started with an error message, and everything started working right when it cleared, and I switched modes. I wonder if the two are related now. I could try to reproduce it in the morning.
Ok, so I confirmed the issue. If I start the comms with no air supplied to the PM, I get an error (0-22-0). So long as the error is present, it wont update the tool tip for amps, and I cant change air pressure to anything but 0. I can adjust amperage and modes though.
As soon as the error is clear (turned the air on), the tool tip shows up for amperage, and I can change pressures necessary.
So the two glitches are:
1. tooltip over amps doesnt update if theres a fault on comms enable startup
2. cant adjust pressure to anything but 0 when there is a fault on the PM.
Note: The two glitches are only the case if there is an error on startup. If I clear the error, and reintroduce the error, everything still functions as it should.
For good thorough measure, I disabled the comms to get panel access back on the PM, and it WILL let you adjust pressure to manual mode without any air supplied. I thought maybe the PM itself was preventing this, but that does not appear to be the case.
- snowgoer540
Might have to troll the internet with that one LOL
Can you confirm that all these issues arise only when you try connecting with an error present.
