GUI for PlasmaC - QtPlasmac
5 years 8 months ago #197783 by phillc54
Thanks for the report, I pushed the fix.
The following user(s) said Thank You: robertspark, snowgoer540
5 years 8 months ago #197815 by robertspark
rodw wrote: Sorry thats the wrong file location. for me its in
~/linuxcnc-dev/configs/by_machine/qtplasmac
If you are not compiling from source it will be in a different location and you probably need to use sudo when opening your editor.
I have used the ISO install + buildbot (idiotproof setup in case I do something wrong and need to start again with my learning, and a quick start again)
5 years 8 months ago #197986 by rodw
Replied by rodw on topic GUI for PlasmaC - QtPlasmac
How hard would it be to provide the same functionality the estop GUI button has to the POWER button?
Reason being that I've been playing around with a safety relay and it requires a momentary switch (eg. the green button in the pic) to reset the relay after an estop so it does not make sense to also require a gui button press.
Early days yet...
5 years 8 months ago #197988 by phillc54
The green button seems more like a Estop reset than a power button to me.
5 years 8 months ago #197990 by rodw
No it needs to be pressed to enable the circuit on power up even if the estop is not triggered.
5 years 8 months ago #197994 by robertspark
latching circuit / latching enable?
Time to create page: 0.185 seconds
