- Thank you received: 5334
PlasmaC Fiber laser 1Kw head height control + auto focuas
6 years 1 month ago #180598
Replied by PCW on topic PlasmaC Fiber laser 1Kw head height control + auto focuas
You _can_ use encoder pins as GPIO inputs
That is, special _input_ functions can always be used as GPIO
(of course you cannot use the encoder if A or B are used for GPIO)
The following user(s) said Thank You: tommylight, taloot
6 years 1 month ago - 6 years 1 month ago #180677
by taloot
in your example u use 3 and 5 ... this number is I\O number (FPGA PIN number)
in my firmware that PCW make... i will use the NONE labled pin
which is 1 3 13 18 20 30
Replied by taloot on topic PlasmaC Fiber laser 1Kw head height control + auto focuas
and the GPIO pin number is represent the FPGA numbertommylight wrote:
To any pin that is not used as and stepgen or PWM or encoder.taloot wrote: how about limit switch
to which pin it go.. quad A and B ?
All of them can be used as inputs or outputs, just set them in hal, like so:ORCode:# --- DOUT-00 --- setp [HMOT](CARD0).gpio.005.is_output true #net dout-00 => [HMOT](CARD0).gpio.005.out net plasmac:float-switch => [HMOT](CARD0).gpio.005.out #setp [HMOT](CARD0).gpio.005.invert_output trueThose are just examples, edit them to suit what you need.Code:# --- PROBE-IN --- #net probe-in <= [HMOT](CARD0).gpio.003.in_not
Last edit: 6 years 1 month ago by taloot.
6 years 1 month ago - 6 years 1 month ago #180686
With a parallel port BOB you would use DB25 pins 10,11,12,13 and 15
as inputs, these map into:
So 10 inputs are available as GPIO inputs for limit switches etc
P2
DB25 GPIO
10 13
11 14
12 15
13 16
15 03
P1
DB25 GPIO
10 30
11 31
12 32
13 33
15 20
Last edit: 6 years 1 month ago by PCW.
The following user(s) said Thank You: taloot
6 years 1 month ago - 6 years 1 month ago #182270
by taloot
long time since last update
everything works OK... thanks for the big help..
but now i have an issue... and its the last one
the focus i use 4th axis setup
it works ok if i jog it.
but i cant sent the axis to specific command potion without having joint following error
its because the qtpy sent the exact location to the axis.. which generate this error...not ramp to it
so how can i send axis to specific location using halcmd
i cant find solution for this
i want to send a command like in MDI..
i know that from halui i can do it... but is it valid while program is running?
also plasmac probe twice.. how can i make it once
6 years 1 month ago #182304
by phillc54
You may be able to achieve this with a HAL component that utilises external offsets.
linuxcnc.org/docs/2.8/html/motion/external-offsets.html
Replied by phillc54 on topic PlasmaC Fiber laser 1Kw head height control + auto focuas
I don't think it is valid.taloot wrote: so how can i send axis to specific location using halcmd
It probes twice if it senses the probe before it has reached Probe Height set in the Config Panel. You could increase Probe Height until you finf the value that suits your machine and material.also plasmac probe twice.. how can i make it once
6 years 1 month ago - 6 years 1 month ago #183331
by taloot
i rework the capacitance sensing
is there any command allow me to test the head follower aka thc
without running programe
Time to create page: 0.138 seconds
