PlasmaC Fiber laser 1Kw head height control + auto focuas
6 years 7 months ago #162298 by rodw
ohmic documentation is here
linuxcnc.org/docs/devel/html/man/man9/ohmic.9.html
The source for both plasmac.comp and ohmic.comp live in git in this folder:
github.com/LinuxCNC/linuxcnc/tree/master/src/hal/components
You may also be able to modify the plasmac probing to do what I was thinking.
The following user(s) said Thank You: taloot
6 years 7 months ago #162340 by taloot
rodw wrote: ohmic documentation is here
thanks alot,,, i will try it,,, and i will update
6 years 6 months ago #162557 by taloot
okey i have update,,
it seems all good,. except one thing,,
auto foucas motor inside the head is considered as 4th axis,,,and i should adjust it according to the cutting height and material thickness also cutting or piercing,, whats the best approach to fix that
6 years 6 months ago #162559 by andypugh
You should be able to configure the focus motor as an axis if you think that will work best. That means that it would be controlled from inside C-code by an axis letter.
But, whether this is a good idea or not would depend on the source of the information used to control the motor.
I suspect that it would be better to control the motor inside HAL, independently of G-code commands. (in very nearly exactly the same way as torch height is controlled with a Plasma machine)
6 years 6 months ago - 6 years 6 months ago #162572 by taloot
i dont think its good idea,,,
it relies on factors
1, distance between head and work-peace (piercing and cutting have different focuas
2 material thickness
3 speed of cut ( fine tuning)
its better to be configured same as material,, in plasmac
Last edit: 6 years 6 months ago by taloot.
6 years 6 months ago #162614 by phillc54
Time to create page: 0.111 seconds
