Hallo phillc54The color is changed
Everything is as normalwith the difference of colorsPower on is greenPower off is red
Start Program Press the E-Stop Button goes green
you can switch the program in on by using the power button" E-Stop green Power Button green the Programm runing "
If you press the E-Stop E-Stop and Power Button goes red !
The logic is that something is on, it is green, something is off, it is red E-Stop presses red E-Stop reset green
step 1,2,3 Everything is correct without an external E-Stop.
With e-stop installed with e-stop 2,3,4
The internal e-stop is always green when the external e-stop is not pressed
that's not ok it should be red and after pressing it should turn green
If the external e-stop presses, it the internal e-stop red, that's ok
after reset is the internal e-stop green !
but I want be internal e-stop red and after pressing internal e-stop then only green !!
King regarde and
thank’s
Juergen
