PnP feeder
5 years 3 months ago #213739 by my1987toyota
Replied by my1987toyota on topic PnP feeder
I Just ordered a 7i71. Those 48 output channels will sure come in handy. I wonder how many additional feeders I can utilize?
OK andypugh you will probably win but. Race ya.
5 years 3 months ago #213798 by andypugh
Replied by andypugh on topic PnP feeder
I haven't even plugged mine in yet. It turned up on eBay at a time when I am not short of projects, and don't really need a PnP.
The following user(s) said Thank You: my1987toyota
5 years 3 months ago #213843 by my1987toyota
No problem. At least it got me back to doing my PnP project. I wish you well on your's if or when you get to it.image missing /media/kunena/emoticons/smile.png
5 years 3 months ago - 5 years 3 months ago #214053 by my1987toyota
 So my Mesa 7i71 board came in today. Now to figure out how to activate the feeders with it. I know I will be using hal. to tell
Linuxcnc what wires actuate which feeders . But I now have to figure out how to map an M code say M100 to facilitate action.
A big question is, is it possible to have the machine placing it's part while at the same time advancing
the feeder it just pulled from? This feels like very uncharted territory ( especially for me ). I have always built simple machines
nothing with an ATC or the like.  Any suggestions will be greatly appreciated .
Looks like I have a lot of reading to do. image missing /media/kunena/emoticons/unsure.png
Last edit: 5 years 3 months ago by my1987toyota. Reason: updating info
5 years 3 months ago #214068 by andypugh
It might make sense to use OpenPnP as the front end, I think that it can be set up to use LinuxCNC purely as a motion planner.
Alternatively:
You can probably use T to pick a feeder. But what about if you want to do real toolchanges of the picker nozzle?
Maybe the way to so that is to have a tool table that contains the X and Y of the feeder and use Z (or pocket?) to pick the nozzle.
Or use T1003 to switch to nozzle 3?
As you have noted, there is a lot to decide. It needs to be mapped-out between the input file (Centroid?) and the final canonical movement commands.
I don't see anything in a Centroid file that chooses nozzles, so I think that must be part of machine setup, where each feeder is associated with a nozzle somehow. Which does feel a bit tool-table-like.
The practical solution is probably a Python front-end that interprets the Centroid file, and a purpose-designed setup file for that which decides which feeder has which part, what orientation they are in the tape, and which nozzle should be used. That can then queue-up a set of simple subroutines for the various tasks.
Better would be a dedicated pluggable interpreter and a new Task module. :)
I suspect that the "Front end" that I suggested above can easily be OpenPnP, which would save a lot of work, I suspect.
5 years 3 months ago #214150 by my1987toyota
Their have been some who are trying what you suggest . I am just not sure I will go that route . Who knows they are probably on the
forum.
www.youtube.com/channel/UCTryBiDBBzWmkGBlxTgyswg
Time to create page: 0.520 seconds
