Sample Qtvcp Screens
5 years 1 month ago #221357 by persei8
Replied by persei8 on topic Sample Qtvcp Screens
The qtdragon_postgui.hal that is on github is simply a convenience for simulation. Ditto for qtdragon.hal. Your files will be specific to your machine. The probe functions are the same as before. In the ini file there is a section like:
[PROBE] USE_PROBE = basicprobe #USE_PROBE = versaprobe
Uncomment the one you want  to use.
5 years 1 month ago #221363 by billykid
Replied by billykid on topic Sample Qtvcp Screens
I put my files and the machine works 4 axis and vfd spindle. I can't explain myself well .. I don't know if these are needed in the qtdragon_postgui.hal file:
net xwidth motion.analog-out-00 => qtdragon.x_width
net ywidth motion.analog-out-01 => qtdragon.y_width
net avg_dia motion.analog-out-02 => qtdragon.avg_diameter
net edge_angle motion.analog-out-03 => qtdragon.edge_angle
net edge_delta motion.analog-out-04 => qtdragon.edge_delta
net xminus motion.analog-out-05 => qtdragon.x_minus
net yminus motion.analog-out-06 => qtdragon.y_minus
net zminus motion.analog-out-07 => qtdragon.z_minus
net xplus motion.analog-out-08 => qtdragon.x_plus
net yplus motion.analog-out-09 => qtdragon.y_plus
net xcenter motion.analog-out-10 => qtdragon.x_center
net ycenter motion.analog-out-11 => qtdragon.y_center
net cal_offset motion.analog-out-12 => qtdragon.cal_offset.
because if I insert them from this error: qtdragon_postgui.hal: 29: Pin 'qtdragon.x_width' does not exist
5 years 1 month ago #221365 by robertspark
Replied by robertspark on topic Sample Qtvcp Screens
The latest version of QtDragon_hd. Main differences are:
- added joypad widgets for jogging and program control
- support for an MPG
- replaced override sliders with adjustment bars
- new stylesheet
- several operational improvements
If you want to check it out, all the files are at github.com/persei802/QtDragon_hd
Ignore the blank space at the bottom of the screenshot. That's because my laptop has a UHD screen.
That is a really nice screen.
I wish there was one for turn that nice.
I have had a dabble at changing various screensets for turn and also having a go at creating my own, wow, lot of work and imagination involved.  I take my hat off to you now I am dabbling more with the code side of things.
The following user(s) said Thank You: persei8
5 years 1 month ago #221381 by persei8
The probe routines don't use analog signals. You can delete them all.
The following user(s) said Thank You: billykid
5 years 1 month ago #221519 by robertspark
QT Dragon HD, Argentium style sheet (+ others too)
Just wondering how you spin boxes are tabulated / filled with text, mine are blank, unless if I select the simple style sheets then they are populated with text.
ideas, what I am doing wrong?
5 years 1 month ago - 5 years 1 month ago #221536 by hottabich
Replied by hottabich on topic Sample Qtvcp Screens
The woodpecker1580x960 interface scored the most views on YouTube. I suggest those who wish to test. Reviews are welcome. For Linuxcnc 2.8.2. files.dp.ua/ru/mSPXc   Video
Last edit: 5 years 1 month ago by hottabich.
Time to create page: 0.204 seconds
