Sample Qtvcp Screens
3 years 9 months ago #262761 by rodw
Replied by rodw on topic Sample Qtvcp Screens
When I instlaled woodpecker 1536 x 868 the other day, I got no styles.
now I get the screen formatted way bigger than the physical screen, even if I changed the display to full hd
I deleted prefs and var files,
But its now styled but still oversized
Any ideas?
3 years 9 months ago #262764 by rodw
recloned from scratch and updated the prefs file to use my home folder. The styles are now OK but its still oversized...
3 years 9 months ago - 3 years 9 months ago #262770 by hottabich
Replied by hottabich on topic Sample Qtvcp Screens
Unzip the archive to the linuxcnc/configs folder. Place style files and woodpecker.qrc with replacement at usr/share/qtvcp/screen/woodpecker, you will be able to switch styles from settings tab. The size changes to F10(min), F11(max). In the woodpecker_xyza.ini file, remove -f from the DISPLAY section.
Last edit: 3 years 9 months ago by hottabich.
3 years 9 months ago #263039 by cmorley
Replied by cmorley on topic Sample Qtvcp Screens
I modified qtdragon to add a qsplitter (the white line) between the gcode display and the gcode plotter.
You can adjust the split to some degree or completely pick one or the other.
If someone wants to test I can post the file.
I think it might be good enough to make standard - opinions?
3 years 9 months ago #263040 by cmorley
Here is with it split to full gcode.
3 years 9 months ago #263041 by rodw
Seems to not be resizing horizintally, The sreen @1536x834 kooked squashed, but on 1080p, the resizing stuff might need some work
I did delete prefs file
This is a chromebook so might be a bit odd.
Time to create page: 0.073 seconds
