ESAB Ultrarex UXD-P 2500 retrofit with Linuxcnc and Proma THC
6 years 8 months ago - 6 years 8 months ago #156785 by alexandrub
In this case you use the computer paralel port to command the z stepper driver and 6i25 to command the mesa 7i77? The control panel from esab is working now or is just for design? You assign all the key?
Can I use a doughter card from mesa to comand the z stepper motor?
Last edit: 6 years 8 months ago by alexandrub. Reason: I forgot a question
6 years 8 months ago #156786 by tommylight
alexandrub wrote: In this case you use the computer paralel port to command the z stepper driver and 6i25 to command the mesa 7i77?
Yes.
alexandrub wrote: The control panel from esab is working now or is just for design? You assign all the key?
The client was not interested in using the control panel at all, i was since i already have 2 of 7i73 boards. He won ! :)
alexandrub wrote: Can I use a doughter card from mesa to comand the z stepper motor?
You can use the other port on the 6i25 to drive the stepper, but you would need to flash the 6i25 with different firmware. You should use a BOB to protect the 6i25, just in case.
6 years 8 months ago #156789 by alexandrub
You can use the other port on the 6i25 to drive the stepper, but you would need to flash the 6i25 with different firmware. You should use a BOB to protect the 6i25, just in case.[/quote]
What is a bob? Can you give me an model?
6 years 8 months ago #156792 by tommylight
6 years 8 months ago - 6 years 8 months ago #156808 by rodw
If it was possible to add an encoder to the Lifter mechanism, you might be able to use the 7i77 or a Linuxcnc PID component to control the lifter. You need position feedback so you can set pierce height and starting cut height positions.
Last edit: 6 years 8 months ago by rodw.
6 years 8 months ago #156835 by alexandrub
From your experience, if i use a stepper, what is the minim torq i need to use for lift z axis? I need closed loop ?
Can you tell me what breakoutboard do you use for retrofit the esab plasmacuter?
