progress has been slow, due to... lack of ambition, maybe.
I have so far selected a mounting board (3/4" birch plywood), and covered the surface in copper foil tape for shielding. i then mounted the Mesa card to it using some L PCB mounting feet. i did the same for the 50-pin breakout boards, and the 5v <--> 24v optoisolation modules (each is 4 channel). the ribbon cables from the Mesa card to the breakout boards have been wrapped with copper foil tape, and grounded to the mounting board shielding. the mounting board, when complete, will have a perimeter of wood wrapped in copper foil tape, and a cover that is also shielded. the idea being that all of the control logic will be shielded, and the wires coming in and out will also be shielded (shield drain tied to the mounting board copper).
next to do, is to connect jumper wires from the breakout boards to the optoisolation modules. these are short runs (3" to 6"), so i may be fine with unshielded twisted-pair wires, only because shielding them will be a PITA. i may shield them in the future, if needed.
the stepper drivers will not be mounted on the control mounting board, simply because the mounting board i selected didn't have as much room as i thought it did. they will be mounted to the base of the enclosure, with shielded cable (CAT5e STP) feeding the logic. the power wires feeding the stepper drivers will be made to be twisted-pair.
now, i have changed my mind on the source of power for the system. previously, the power was a few switch-mode power supplies (120Vac input), as well as a ATX computer power supply (supplying 5Vdc, and 12Vdc), and a 24Vdc wall-wort. what i will be changing to, is rather than relying on 120Vac grid power, i will use a couple 12V lead-acid (or AGM) batteries, kept up with an automatic 120Vac charger, and solar power. this way, the power is stable during a power failure, giving me time to either save and shutdown the machine, or with enough battery storage, keep running. the LCNC computer will have a UPS as well, and eventually a standby generator. so with this in mind, i will use a series of step-up and step-down DC-to-DC converters to get the 5V, 12V, 24V, 36V power buses. the only thing that will not get power, will be the spindle, so likely i won't keep running, but will save and pause, and enable a resume button when the power is restored via either grid power, or from the standby generator. so i will need to wire a relay to the grid power, and connect it to activate the E-Stop on power failure.
as for shielding the control enclosure, my choices are to either cover the inside in copper foil tape, or use sheet metal screws to bond the painted panels together. the screws may be easier, but i think the copper foil may be more reliable. i will have to think on that portion.
i also have plans for this spring/summer to move my machine from the old gutted out camper, to a to-be-built shed. working inside the old camper has a lot of disadvantages, mainly lack of room around the machine. with the larger shed, i can also feed it with a sub-panel, and 6AWG wire from the main power panel, as opposed to the 10AWG wire feeding the camper. this will enable more available power for a larger dust-collection system, rather than the shop-vacuum i have currently.
i hope to have the control mounting board more complete by tomorrow, and i will try to remember to take a few pictures. the shiny copper foil definitely adds to the appearance.
~Travis
